CL-Class (W215) 2000-2006: CL 500, CL 600
Door Handle Button Not Working
Old Jan 3, 2023 | 05:29 PM
K McCarthy's Avatar
2002 CLK 430, 2005 CL600, 2009 Smart Fortwo
Hi, my door handle button no longer works on the drivers side. I assume the button has failed but as you all know, on these cars surprises often happen. Has anyone else experienced this and what was done to fix it? Thanks for your replies. 2005 CL600.
Old Jan 5, 2023 | 11:05 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
If you have access to a DAS/Xentry system, it can test the button directly in the door control module.
Its worth troubleshooting that way first, there is a lot of disassembly to get the door handle in/out.
Old Jan 6, 2023 | 02:04 AM
BenzNinja's Avatar
Former Vendor
extremely well known problem
easy to fix
https://www.youtube.com/results?sear...utton+mercedes
and for the IR sensor here:
Old Jan 6, 2023 | 08:42 AM
K McCarthy's Avatar
Thanks for the advice!
Old Jan 10, 2023 | 05:39 AM
renault12ts's Avatar
W215 CL500 2005
Is it that easy on the W215 though? I don't think so.
Old Jan 10, 2023 | 09:38 AM
K McCarthy's Avatar
Yes, also this is not my issue. The video seems to be for the IR sensor. My issue is the button which locks the door. My keyfob works fine.
Old Jan 10, 2023 | 06:25 PM
BenzNinja's Avatar
Former Vendor
you didn't even look in the search results in youtube
pick the one with the button
Old Jan 11, 2023 | 07:33 AM
tim687's Avatar
CL 600 '00 5.8L V12
Check out my guide here: https://www.benzworld.org/threads/ho...ttons.3105867/
Old Jan 11, 2023 | 08:36 AM
K McCarthy's Avatar
Thanks tim687! Very helpful.
