CL-Class (W215) 2000-2006: CL 500, CL 600
cl500 keyless go door buttons
Old Jan 4, 2023 | 09:58 AM
glennn's Avatar
cl500 2001 /320 c208 convertible 67k
Hello
I know this has been covered times before but I rang a couple of mercedes dealers today to get price and availability for both front door handles, just the pull handles but was told by both that there are none available in the UK or Germany and probably discontinued.
Is it at all possible to repair them . Ive bought " secondhand working" but they don't.
Old Jan 5, 2023 | 11:12 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
S-class handles are more widely available used. From what I've learned they're identical but have a different harness, one is male and the other is female, I don't recall which is which.
I have one siting on the workbench waiting to go in, just planned to splice in the CL harness into the donor S handle. I lost the keyless go card and haven't upgraded to use a newer key, so it hasn't been a big rush.
Old Jan 8, 2023 | 05:53 AM
glennn's Avatar
Hello
Thats encouraging but still can't find much on ebay at least.
Don't suppose mercedes had the foresight to use the same handle front and rear on the w220.
Old Jan 9, 2023 | 10:42 AM
tim687's Avatar
CL 600 '00 5.8L V12
Why don't you repair the buttons?
Old Jan 9, 2023 | 11:01 AM
glennn's Avatar
Hi
Because as far as I'm aware they cannot be repaired as they are sealed in epoxy . New rubber button covers are available but no good if the water has done the damage already.
About an hour ago I bought a s/h pair from a specialist breaker so fingers crossed.
There's new available from a couple of places in the USA but neither would post to the UK.
Old Jan 9, 2023 | 11:54 AM
tim687's Avatar
CL 600 '00 5.8L V12
I've repaired mine.
https://www.benzworld.org/threads/ho...ttons.3105867/
Old Jan 9, 2023 | 12:05 PM
glennn's Avatar
If I don't have any success with the ones I've ordered I'll look into that
Cheers
Old Jan 11, 2023 | 11:47 PM
mekantor's Avatar
Originally Posted by glennn
Hello
I grabbed a VIN of a random 2003 S600 that I found on eBay, with Keyless Go, and entered it into EPC.
Front and rear door handles had identical part numbers on both sides.
Old Jan 12, 2023 | 10:55 AM
glennn's Avatar
That is brilliant news
Old Feb 2, 2023 | 09:35 AM
glennn's Avatar
Well the two handles that i was hoping to get from the USA have come to nothing as no eta on them so going to try repairing them as per tim687's link.
Microswitches came today and I've drilled out to allow for access.
Old Feb 3, 2023 | 04:40 AM
tim687's Avatar
CL 600 '00 5.8L V12
Enjoy the process! :-)
Old Feb 5, 2023 | 10:08 AM
glennn's Avatar
I ground a channel in the epoxy to sink the wires into ,wired it up with a new button and it all works OK at the plug.
I've held the wires in place with tape then filled with pu adhesive/sealer then I'll take the tape off and fill too.
Old Feb 6, 2023 | 12:13 PM
glennn's Avatar
Fitted the handle and all seems to work well.
Passender side to go.
Old Feb 6, 2023 | 06:21 PM
Fried Chicken's Avatar
2005 S500 Designo
Interested in this as well. Do I need replacement micro-switches? Aliexpress screwed up with the registration and don't want to deal with ordering from the linked posted on benzlworld.
Old Feb 7, 2023 | 01:13 AM
glennn's Avatar
Yes you will.
Got mine from rs components
Switch Tactile J bend soft 3.5mm 1.6N
Stock no.:894-9032
Resistor I found on ebay
https://www.ebay.co.uk/itm/302605846036
I didn't need to remove as much material from the handle as I did. Drilling 1/2" down through the crosshairs and then straight down through the epoxy with a 5mm bit is enough.
Old Feb 13, 2023 | 08:18 AM
glennn's Avatar
Now got the passenger side done too. Drivers side has been working just fine.
If anyone wants theirs done but dont fancy doing it themselves I still have some buttons and resistors left.
Old Feb 13, 2023 | 08:37 AM
tim687's Avatar
CL 600 '00 5.8L V12
I might give your buttons a try, as my button has failed on me. It was a chinesium button, so that might explain it.
How are the dimensions of your button compared to mine?
Old Feb 13, 2023 | 09:57 AM
glennn's Avatar
Approx 6x6mm
Old Feb 13, 2023 | 12:24 PM
tim687's Avatar
CL 600 '00 5.8L V12
And the thickness?
Old Feb 13, 2023 | 12:29 PM
glennn's Avatar
3mm
Not an issue as you just have to be careful how far you set it in.
Old Feb 14, 2023 | 04:04 AM
tim687's Avatar
CL 600 '00 5.8L V12
I asked just to compare against my buttons, which seem to be slightly thicker
Old Feb 14, 2023 | 04:11 AM
glennn's Avatar
Shouldn't make a difference as once drilled out you can set them in as required
