CL-Class (W215) 2000-2006: CL 500, CL 600
2002 cl500 correct PS fluid when doing conversion coilover
Old Jan 11, 2026 | 11:33 AM
JLS500's Avatar
2001 S500
Ok so I’m alittle confused as to what PS fluid to use.
abc system has hydraulic fluid but when you remove the power steering pump with a s500 pump the s500 pump uses regular power steering fluid from Mercedes.
so my question is do I use the CHF111
or regular PS fluid.
what will happen to the rack impinion if you switch fluids
i have yellowspeed coilovers that came with the car and I hate them.
i have a RT front wheel hop at 60mph and have replaced every wearable on the front end except for the strut and the steering rack.
i even added the front sway bar from a s500 to see wheel shake would go away.
