CL-Class (W216) 2007-Present: CL 500, CL 600
Mercedes CL500 W216 Auxiliary Batter ( Need Help)
Old Jan 7, 2016 | 04:04 PM
shon53's Avatar
Mercedes CL500 2010
Smile Mercedes CL500 W216 Auxiliary Batter ( Need Help)
hello,
i need to replace my auxiliary battery on my merc , please help me with that.
where the auxiliary battery located on my car?
i will be glad if someone could send me an instruction or a video help.
thx,
Shon.
Old Jan 15, 2016 | 05:05 PM
college66's Avatar
Mercedes CL63 AMG
Hi Shon53
Just changed by aux battery on my CL63. If you look at the back of the boot ( i.e back of rear seats) the entire vertical panel is removable and the battery is behind there. Lift the panel from the bottom and pull it upwards, it will then stay in place above you.
Old Jan 16, 2016 | 02:19 PM
2014CL600's Avatar
Cars
Old Jan 16, 2016 | 02:45 PM
college66's Avatar
Mercedes CL63 AMG
Originally Posted by 2014CL600
Depending on your year, in the U.S., the CL as of MY2011, did away with the auxiliary battery.
My car is a 2007, so that would explain this. That said, 2 MB dealers in the UK gave me the wrong position.
This is the least of probems, my CL63 has a major engine issue as posted on here with a Star diagnostic code and I am waiting for someone who really knows the M156 engine to offer some advice.
Help someone please.
Old Jan 16, 2016 | 02:54 PM
2014CL600's Avatar
Cars
Old Jan 27, 2024 | 12:41 AM
Bongo7777's Avatar
Mercedes 2013 GL500
W216 2011 CL500 Auxiliary battery, distronic cruise fix.
The 2011 W216 CL500 auxiliary battery is behind the fuse box driver side dash. It is a tiny battery, part (N 000000-004039) that allows you to take the vehicle out of park if your main battery dies (among other functions). The Distronic cruise will not work if the auxiliary battery voltage is below 12.3V!
Remove 2 torx screws to allow you to pull the small fuse box out and move it aside. A 10mm bolt holds the battery box. If you have large hands, you may also need to remove the lower dash panel as it is a bit fiddley! Pull the connectors off and remove the battery. You could try charging the battery with a trickle charger or just buy a new one.
Be careful when you re connect the battery! Make sure you put positive to positive. It's hard to see and I crossed them!!! This blew out the parking brake module!
Old Mar 28, 2025 | 08:10 AM
gregreid's Avatar
2009 CL600 RennTech and 2001 CLK430 AMG
My 2009 W216 CL600 has its auxiliary battery at this same location (behind fuse box, driver's side dash).
Old Oct 28, 2025 | 01:10 PM
NONAM3k's Avatar
I have a 2007 CL 600 that's been sitting in a garage for 7 years. I replaced the battery under the hood and the large battery in the trunk. The car started, but I have some error codes. I looked for a third AUX as YouTube shows on the driver's side under the dashboard, but it's not there. Is there a third AUX battery in the 2007 CL 600 USA?
My error codes are:
1936 no can message was recived from control unit y3/8n4 VGS
1984 no can message was recived from electronic parking breake
20Ea No or incorect can message from control unit ETC
2090 No or incorect can message from electronic parking breake
6100 Test voltage suppy of circuite 87
5831 One or mroe signalos sent from control unit n47-5 ( esp control uniy ) via the can bus is impulausible
5822 incorrect signal or interference in signal transmission from control module n15/3
Old Nov 1, 2025 | 09:20 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
My error codes are:
Oddly, some CL's of this era do not have the small Aux battery, so yours likely is one of those vehicles. Mine does not as well.
Old Nov 2, 2025 | 07:12 AM
PhoenixOp's Avatar
2002 Mercedes Benz SL500
NONAM3k;
My '07 does not have a battery behind the glove box, so you did the correct thing by replacing the other two after sitting for 7 years (which is a crime in itself).
As for the codes... Clear all the codes, start it up, drive it, and see what comes back. It's possible those are old stored codes from way back, so start with a fresh list and work from there.
See ya!
Michael
