2007 CL 500 dynamic seat leackage
Hope anyone can help with the procedure. Thanks
When I get time to pull my seats out Im going to to diagnose witch bladders are leaking and simply block them off so the remainder of the system will operate. I like the active seat function and want it working full time. For those reading that dont know what that is, it is when you make a turn the opposite side left or right seat bolster inflates to hold you in the seat better. Its actually cool and secures you in the seat. Based on what happens when I inflate various bladders. The ones that dont work are the ones with leaks etc. For example I go into the command center and try to fill my lumbar support and it wont fill. Same with a few others too seems the only ones left that actually work are the seat back sides. So in short Ill block everything but those and get the system working with just the 2 sides. Once I know what it needs Ill go by the dealer and see if any of it is still available. Im sure it wont be cheap either since nothing on this car is. But what a car huh? I love it and if I can get it all perfect I will.
