CL-Class (W216) 2007-Present: CL 500, CL 600
W216 rear driver suspension lean
Old May 4, 2018 | 08:04 PM
COUPCONNOISSEUR's Avatar
2010 CL550
so my CL was in storage for the past 9 months..being started and warmed up every week or so. after getting it on the driveway this week i noticed the rear driver side is sitting slightly lower(i say only slightly because i dont believe it to be bottomed out, ive seen on older s500's the suspension dropped so low that a jack cant even fit underneath, thats definitely not the case here) than the other corners. when i raise the car it comes up some but still not as much as the others. its also not throwing me any codes or messages..im aware it could be a plethora of issues, but where should i start?
thanks
chris
Old May 5, 2018 | 12:40 PM
Jaap's Avatar
2006 W221 S500L M273
Is it not throwing any OBD codes or no mercedes codes?
In other words: did you diagnose it with star/xentry?
There's a procedure in Star for calibrating an ABC strut:
https://mbworld.org/forums/sl55-amg-...ou-do-das.html
Old May 5, 2018 | 12:45 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Is the car parked on a completely level surface? The car will try and level the body relative to the ground so this can only really be checked if its on a level surface.
Old May 6, 2018 | 09:07 PM
2010 CL550
nah, its not throwing any codes.obd or otherwise. and yes its on a level surface. also, this CL is not equipped with ABC
Old Jun 9, 2018 | 08:27 AM
2010 CL550
would it be possible for this problem to have corrected itself just from using it everyday? it doesnt appear to be leaning anymore. any feedback is appreciated
Old Jun 16, 2018 | 03:03 AM
Benztech777's Avatar
2007 Mercedes Benz CL 550
You can cycle the suspension from std to high with the button in the center of the dash and that will self bleed the system some. It should always be trying to reach its target level.
Old Nov 21, 2018 | 12:24 AM
2010 CL550
Strangely enough this problem straightened itself out
Old Nov 23, 2018 | 05:25 PM
lkchris's Avatar
'10 CL550, '12 GL550
His 2010 has airmatic, not ABC.
