CL-Class (W216) 2007-Present: CL 500, CL 600
2007 Cl550 Sway Bars
Old Oct 19, 2022 | 08:11 PM
D@rthV@d3r's Avatar
CL550
Hey all
I replaced my ABC system with a coilover. Hated to do it but no choice the whole system was failing and part are not even available for months. I bought this car used and unfortunately previous owners did not seem to have maintenance in mind at all.
So my question is what is available for this car as far as sway bars for the front and rear go? Also will they mount up? Meaning is it already have the ability to bolt on sway bars front and rear? Without the ABC system body roll is horrible so I am looking to fix that with swaybars.
Dom
Old Oct 20, 2022 | 07:26 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Originally Posted by D@rthV@d3r
Hey all
Dom
I wasn't aware that there was a coil product out there to replace ABC...only seen Airmatic replacements. Would you share your links for the product?
Old Oct 20, 2022 | 08:24 AM
D@rthV@d3r's Avatar
CL550
https://www.strutmasters.com/collect...-module-mu54fm this is the kit. Here is the problem with the kit. No sway bars so you will have to add that which I am doing now so add another 1200 plus dollars to do that plus parts.
Old Oct 20, 2022 | 08:49 AM
nath_h's Avatar
Interesting. Please keep us posted on this project.
Old Oct 20, 2022 | 08:50 AM
D@rthV@d3r's Avatar
CL550
Will do!
Old Oct 30, 2022 | 08:56 AM
INEEDIT's Avatar
CLK430
Will do!
did you find a solution?
Old Nov 4, 2022 | 01:27 PM
D@rthV@d3r's Avatar
CL550
still working on it
Still working on it at this point. We have rear sway bars in but the front is proving difficult. I will know more next week. As the car setup on ABC is different from airmatic so the airmatic sway bar would not fit as the housing of the transmission and how the motors is mounted will not allow for the sway bar. we have another one coming that looks like it would fit.
My mechanic also let me know if there is no front sway bar solution some adjustable shocks to stiffen and lower the front end might be the only solution. I was already looking at these in the long run anyways I just went strutmaster because that was a fast solution. https://titansuspension.com.au/produ...40054005891171 those are what I wanted in the first place but they have to come out of Australia. Will let you know next week once I see how that goes. I am praying to the old gods and the new that the swaybar that is on its way will work and I can do this upgrade down the road and not have to do it now.
Old Nov 4, 2022 | 02:01 PM
INEEDIT's Avatar
CLK430
Lots of people on the forum also swear by the Yellow Speed Racing Coilovers. Adjustable system also. From the good ol USA. But it seems like you already invested in a system and are trying to make that work.
This guy used strutmasters and said they worked fine alone...
His email is in there if you want to reach out to him.
Old Nov 7, 2022 | 10:17 AM
D@rthV@d3r's Avatar
CL550
Yeah my problem is that those guys did not make a system for my car or I would have gone down that road for sure!
Old Nov 7, 2022 | 10:19 AM
D@rthV@d3r's Avatar
CL550
and as for my sturmasters I think it depends on what system you are coming off of. Coming off the ABC system the body roll is just really bad. We have the rear sway bar going in this week finally and I will see about the front later in the week.
Old Nov 14, 2022 | 07:41 AM
nath_h's Avatar
When you say body roll is bad...how bad are we talking about? Does the new setup work okay for normal driving, or are you having body roll problems when pushing the car hard around corners or whatever? My car is primarily a highway cruiser, and never gets thrown around. I don't need to change my car yet, but thinking ahead to solutions when the inevitable problems arise. I'm glad to see there are coil over options, because I was not aware of this for ABC until you posted about it.
Old Nov 14, 2022 | 09:54 AM
INEEDIT's Avatar
CLK430
Dont quote me but I imagine for highway cruising you should be fine. The cars are heavy and the weight seems to be the concern when cornering and if the springs are suited for handling the weight on aggressive driving.
I come away from this video thinking its a good idea/alternative.
Old Nov 16, 2022 | 10:11 AM
D@rthV@d3r's Avatar
CL550
Well it was noticeable when making turns and I would say I am a spirited driver and like to take turns on the straight away it was not bad just making tunrns its noticeable. I invested another 1k in getting a rear swaybar in and that reduced it alot. We looked at a front sway bar but seems to be impossible. MB does not seem to make one but one that might work is off a S600 armored vehicle but it was a bit too pricey for my taste and we are not sure it would work. Parts alone for the front sway bar was around $1300. So I think I am going to live with this as it sits for a bit and eventually will change the front struts to titan ones.
Old Nov 16, 2022 | 10:13 AM
D@rthV@d3r's Avatar
CL550
yea i think if you do not care about handling in turns too much its just fine. If I were to do it over again I would go with the titan setup however as it gives more flexibility with 30 click adjustments on those shocks vs these just being fixed and you get what you get. I will also say the front sits a bit higher now then before but they say that once the springs settle that will change.
Old Nov 16, 2022 | 10:20 AM
INEEDIT's Avatar
CLK430
Front sway bar off the next gen S class wont work? I thought I read that somewhere.
Old Nov 16, 2022 | 10:24 AM
D@rthV@d3r's Avatar
CL550
not that he could find he said for some reason the sway bar that was designated to fit that car would not so as he looked around for possible fitments that was what he came across. I will say with just the rear alone its a huge difference already and I could probably live with how it rides now but I know once I can recover from this part of things I will go with the different shocks. He also said that if I would be able to lower the front a bit it would help but since the strutmasters are non adjustable we cant do that.
Old Nov 16, 2022 | 10:25 AM
D@rthV@d3r's Avatar
CL550
If you find out more about the next generation S class one being a viable solution let me know as I would not be opposed to that either.
Old Dec 9, 2022 | 09:04 AM
nath_h's Avatar
I've been researching doing this project. I don't need to yet, but it would make sense to do eventually. Strutmaster videos make this look like a simple process, at least without doing a sway bar. Did you do this yourself, and was it as easy as the SM video shows? SM says sway bars aren't necessary...after a little bit of time driving your car, how are you feeling about it now?
Old Mar 15, 2023 | 06:24 PM
INEEDIT's Avatar
CLK430
I emailed VVK (https://vvk-usa.myshopify.com/) and I asked them about perhaps making custom sway bars for W215 and they said the below. Maybe they are working on all iterations as well.
"This is Santi. I actually was recently in a conversation with Sean about the CL cars and he did let me know that he is working on a sway bar solution for these cars. Unfortunately it's a little early in the process for him to really have answers many of the specifics in terms of pricing, development and availability date"
That was taken from the email I received.
Hopefully this solution comes out soon and the community has a place to go to when they finally give up on their ABC suspension systems.
Old May 21, 2023 | 09:42 AM
nath_h's Avatar
Any more updates about how your system is working? And, from where did you source the rear sway bar? My ABC is still working okay, but at 15 years old I know it's coming for me.
Old Aug 2, 2023 | 09:58 PM
Blkvip's Avatar
12' E559
jeez i asked vvk few years ago about the 216 chassis and got the same response. id be in a cl63 tomorrow if they came out with a sway bar and coil over kit. i hope they do plenty of interest it seems from the 215 and 216 owners.
Old May 10, 2025 | 06:56 PM
xXStarScreamXx's Avatar
Cl550
Can someone please tell me which rear sway bar to use ? I really need it. I am doing a conversion on 2007 cl550. Front sway bar as i see nobody knows what to use but at least tell us which rear you used.
Old May 10, 2025 | 06:57 PM
Cl550
Hello. Please tell us which rear sway bar you used. I really need it.
Old Dec 9, 2025 | 02:17 PM
nath_h's Avatar
Did you folks who did the conversion use the existing dual chamber PS pump, or put in a single chamber pump from an E550 or the like?
