2007 CL550 Replacing rear abc struts - BenzNinja
I was very very pleased with the quality, the struts were around $550 each. Each had a $200 core charge that is refunded after returning old strut(s). Postage to return old strut(s) is included in the above pricing. Also want to give a nod to Peter "BenzNinja" for helping me complete the final step… Level calibration, and plunger calibration. I purchased Peter's program about two years ago and his service has paid for itself 10X over the last two years. He assisted initially with the purchase of the laptop and additional diagnostic equipment, remotely signed in and programmed everything, and has helped diagnose-program any issues I have had with over last 2 years! Thanks Peter!!!!
have a pump at the ready, something as little as a bicycle pump can work as long as you tape it to the dipstick hole. A 12v pump is fine but the pressure happens very quick and if you seal the pump to the tank well, you could blow it up. I’ve used a pump where you can set it to turn off as well, like 10-15 psi, for ten seconds or less. It does not take much. Give it a little bit of pressure, start the car press raise and go back and pump a couple more times. I wouldn’t recommend it, but you could likely even get away with doing this with your mouth and a tube, ask me how I know. The goal is to pump it before the red light comes on the dash but if it does, just turn the car off pump a little more and repeat. It’s very easy once you’ve done it once, and not really something to worry about unless you add so much pressure to blow up the tank.
and to add, if for some reason, air gets in the system because you suck in the fluid too quickly, don’t worry about it just repeat the process and any air in the lines will self bleed because the system is effectively one line in and one line out for each of the corners. Air goes around the circuit and winds up back in the tank.
