CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 Technical Service Bulletins
Old Sep 13, 2005 | 12:41 AM
vraa's Avatar
2003 CL55
Service Bulletins
TSB Number & Issue Date TSB Title
P-88_70-39 MAR 05 Body - Outside R/V Mirror to Door Seal Damaged
P-68_60-37B JAN 05 Interior - Sun Visor Cover Broken
P-30_30-61 DEC 04 Cruise Control Inoperative
P-54_30-92A DEC 04 Instruments - Cluster Version Coding
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_65-132 DEC 04 Parktronic(R) - Sensors Loose In Bumper/DTC's Set
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-72_29-37 NOV 04 Electrical - Seat/Mirror/Window Switch Lighting Fails
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-63_50-07 OCT 04 Body - Corrosion Between Roof and Quarter Panel Seam
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-77_20-25 SEP 04 Body - Sliding Roof Malfunctions/Code 414 Set
P-82_10-201B SEP 04 Lighting - Front Turn Signal Inoperative
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_40-67A JUL 04 SRS - Warning Lamp ON/DTC's B9183/B91A3 Stored
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-54_18-97 JUL 03 Electrical - Drivers' Door Electrical System Inoperative
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-91_60-57A MAY 03 SRS System - Control Module Service Precautions
P-91_60-58 APR 03 SRS System - Post Collision Impact Sensor Replacement
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-54_30-82A FEB 03 Instruments - 'Display Defective Displayed
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-54_21-67A FEB 03 Lighting - 'Check Left Low Beam' Message Displayed
P-54_30-76 JAN 03 Instruments - '00000' Displayed on Odometer
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-54_30-72 OCT 02 Instruments - Incorrect Engine Rpm's Displayed
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
P-82_85-197 AUG 02 Navigation System - Poor Performance
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
P-83_00-61 FEB 02 Interior - Vinegar Like Smell in High Temperatures
P-82_30-178 FEB 02 Wipers/Washers - Wiper Blades Come loose
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
P-83_40-60 JAN 02 Automatic Temperature Control - Inoperative
Old Sep 13, 2005 | 12:42 AM
vraa's Avatar
2004 CL55
Safety Recalls
2004050015 AUG 04 Recall - Trunk Lid Spring Replacement
Service Bulletins
P-82_85-443 MAR 05 COMAND(R) System - Disc Drive Malfunctions When Cold
P-32_50-24 MAR 05 Suspension - ABC Suspension Humming/Buzzing Noise
P-82_70-314C MAR 05 Cell Phone - High Pitched Whining Noises During Calls
P-82_85-433 FEB 05 COMAND(R) Unit - CD Stuck in Head Unit When Updating
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-82_85-424 JAN 05 Navigation - Navigation Unavailable/No DVD Inserted Mssg
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_62-410A NOV 04 Audio System - No Sound/No Station Memory
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-82_85-374A OCT 04 Navigation System - Erratic Operation/Inoperative
P-82_85-326B SEP 04 COMAND System(R) - Intermittently Inoperative
P-82_70-339B SEP 04 Cell Phone - Extremely Loud DTMF Tones
P-82_70-375 SEP 04 Cell Phone - Intermittent Power ON/OFF/Erratic Operation
P-42_20-49 SEP 04 Brakes - Noise From Rear of Vehicle
P-82_70-338A SEP 04 Cell Phone - Echoing/Noise During Hands Free Call
P-33_15-12 SEP 04 Steering/Suspension - Knocking/Rumbling Noise on Bumps
P-82_85-345 SEP 04 COMAND(R) System - Turns ON/Operates By Itself
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
P-82_85-353 JUN 04 Navigation System - Won't Allow Destination Entry
P-82_62-362 JUN 04 Audio System - Sporadic Sound Interruption
P-82_85-324A MAY 04 COMAND (R) System - Vehicle Battery Low/Dead
P-82_95-322A APR 04 Communications - 'Tele Aid Not Active' Displayed
P-82_85-332 MAR 04 Navigation System - Slow to Start Upon DVD Insertion
P-82_70-327 FEB 04 Cellular Phone - Cradle Kit Applications
P-82_85-301 FEB 04 Navigation System - DTC D300 Explanation
P-82_70-323 FEB 04 Navigation System - Voice Recognition Destination Cities
P-82_70-294 JAN 04 Cellular Phone - Voice Activated Cell Phone Installation
P-30_20-61 DEC 03 Engine Controls - MIL ON/Limp Home Mode/DTC's Set
P-68_49-20 NOV 03 Instruments - Inside Rearview Mirror Motor Deletion
P-82_95-295 OCT 03 Communication Platform - Mobile Identification Number
P-82_95-293 OCT 03 Cellular Phone - Version Coding
Old Sep 13, 2005 | 12:43 AM
vraa's Avatar
2005 CL55
General Recalls
2004090006 NOV 04 Campaign - Audio Gateway Flash Update
2004090004 NOV 04 Campaign - COMAND Head Unit Flash Update
Service Bulletins
P-82_85-412B MAR 05 COMAND(R) System - No Audio/Erratic Operation
S-07_08-43A OCT 04 Engine Controls - CVN Recoding After Module Replacement
vraa's Avatar
2005 CL65
General Recalls
Service Bulletins
P-07_61-47 MAR 05 Engine Controls - Misfire Conditions
Old Sep 13, 2005 | 03:39 PM
proform's Avatar
Ferrrari 458 Lamborghini SL 570-4 Mercedes CLS63
Nice....Thanks!!
Old Oct 3, 2005 | 02:09 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
woah, I think this is the first subforum I've seen this in...
Ricky, can you start one of these things up in the w203 forum?
thanks!
Old Oct 3, 2005 | 02:13 AM
vraa's Avatar
Sure, give me a few hours... !
Old Oct 3, 2005 | 02:15 AM
nlpamg's Avatar
sweet, thanks!
Old Oct 3, 2005 | 03:00 AM
vraa's Avatar
Originally Posted by nlpamg
sweet, thanks!
Done. Tell me how it is in that thread.
Old Nov 15, 2005 | 12:24 PM
ZondaC12S's Avatar
Technical bulletins
Ricky,
Would you be so kind as to post TBs for the C219 (CLS55). I am having a hell of a time with my car's brakes - please see my post under "Squeaking Brakes, the saga continues".
Many thanks and warm regards,
Orazio
Old Nov 15, 2005 | 05:33 PM
vraa's Avatar
Nothing on the CLS is out yet.
Old Feb 16, 2006 | 11:17 PM
rtgogo's Avatar
2001 CL55AMG
01 Model
Any chance you have one of those list for a 2001 CL55? My warranty runs out this summer and I'd love to have a punch list.
THANKS!
Old Mar 17, 2006 | 10:43 PM
mazeema's Avatar
Angry help!!!
i cant find any info on the cl55 i need one before my girlfriend gets here it is her birthday next week oh crap oh crap!!!! in this situation i would be the blue smiled that is nearly ded!!!!!!!!!
Old Mar 17, 2006 | 10:46 PM
vraa's Avatar
Buddy I've seen all three of your posts -- chill out and actually contribute of leave.
Old Sep 10, 2006 | 09:41 AM
V12AMG's Avatar
'09 SL600
Anyone know where I can view a copy of this service bulletin?
Old Nov 21, 2006 | 09:02 PM
KatzManDu's Avatar
CL55 AMG (2001), Audi Allroad (2003)
Awesome list, but...
Is there a list for 2001 model CL55s?
Old Dec 30, 2007 | 10:03 AM
yy17616422's Avatar
PC120
Lightbulb
〖^o^〗^o^ 〖^o^〗
Highschool of the dead
naruto
Old Jun 19, 2008 | 01:14 PM
RicardosBenz's Avatar
2015 CLS400
I'd also like to know where I can view these?
Old Sep 11, 2009 | 09:11 AM
CL55AMGRON's Avatar
2005 CL 55 AMG
AS a newbee could you tell me what I can use is info for. I have a 2005 cl55. do I need to go to the dealer with the recall flagh update? If my car breaks on one of these items will it fixed for free? Sorry I am just new to tsb and recall. My other cars were old muscle cars and I didn't deal with theses. If it saves time and money thats great. Thank fore the info.
Old Jan 28, 2010 | 10:31 AM
ivanj's Avatar
Yugos only
Please do the same for the G Class.
I have chronic window and door lock/latch problems that the dealer will no longer fix under the extended 100k warranty.
Any ideas who at MBUSA I can contact? I have a written contract they will not honor...
Old Jul 15, 2010 | 12:20 PM
CL65_AMG's Avatar
CL65 AMG
Great info - thanks!
would you like additional info from members?
the 2000-2005 w215's had a ABC sensor recall that involves replacing the strut sensors. Since the sensor is an integral part the strut, I don't see how they are going to do it without replacing the entire strut. I checked with the dealer, the recall is valid, for some reason my '05 w215 wasn't listed.
Old Jul 15, 2010 | 01:38 PM
ivanj's Avatar
Yugos only
Please look at the recall info at the top of the page.
IS the recall you have just learned about concerning the ABC sensor this or a new one? Could you quote the ABC sensor/strut recall date and recall number etc so I can ask the dealer, please?
Thanks in advance.
Old Jul 15, 2010 | 01:50 PM
CL65_AMG's Avatar
CL65 AMG
AUGUST 2008 -- Mercedes Benz is recalling 4,564 MY 2001-2006 CL-Class (Model 215), MY 2002-2006 S-Class (Model 220), MY 2003-2007 SL-Class (Model 230), MY 2007-2008 CL-Class (Model 216), and MY 2007 S-Class (Model 221) passenger vehicles equipped with Active Body Control (ABC) acceleration sensors on the front struts. These sensors measure acceleration around the Z-axis of the vehicle and assure an automatic adaptation of the front struts to maintain a relatively level body position. Variations in the soldering process resulted in soldering points on the board of the ABC sensors which may not be within design tolerances. Signals from the affected sensors measuring the acceleration may not be accurately transmitted to the engine control unit. A variation in the transmitted values between affected and unaffected sensors can result in one front strut adjusting to a value indicating body movement while another strut does not adjust presenting the driver with an uneven front suspension. This condition may lead to unexpected body movements at the front axle which can adversely influence the vehicle's directional stability and could lead to a vehicle crash. Dealers will inspect and replace, if necessary, the front ABC sensors in all potentially affected vehicles. The recall is expected to begin during September 2008. 08V405
Old Jul 15, 2010 | 04:33 PM
ivanj's Avatar
Yugos only
From the amount of 215 this would seem to cover the lion's share. How do I know if my vehicle is covered by this recall? If I call the dealer is there a "secret code" I can tell them other than the August/September 2008 recall?
Thanks!
Old Jul 15, 2010 | 04:38 PM
CL65_AMG's Avatar
CL65 AMG
call the dealer with your VIN number. They will use it to check for all recalls.
