CL65 Mods
I have a friend that had his SL65 lowered by my old aftermarket guy. He tells me that the Carlsson unit lowered the car about 1 in., but it raises at speed. He also had the software upgrade done, but again by the guy that is out of business.
Has anyone had their CL65 lowered. If so, what unit did you use and how much did it drop the car. Also, how about the software.
Renntech also has an airbox you can get, which in combination with the ECU will give you something like 20 more horsepower and save a bit more weight still.
Other than this leave the car alone. If you want a good deal on some of these parts, you can contact some of the guys that advertise on the forum. In particular, I recommend Neal at Euroteck, www.euroteckmotorsports.com.
The ECU is a drop in, you don't need a "shop" to do it. If you can unplug a couple of harnesses, you can do it yourself. The airbox and the lowering module require a bit more work, but anyone familiar with some MB basics should be able to do it. You can also lower the car a bit through STAR diagnostics, but the Kleemann module allows much more adjustability and will not let the car go too low at high speeds when the ECU drops it anyway.
Please do post some pics, even stock, we love stock pics. Congrats and nice choice on a car!
Your right about the wheels. On my CLS55 and E55 (just sold) I put on Carlsson's untra lights. Lots of weight saving over stock. I bought the CL for my wife and she wants something different this time, so I'll have to be patient with her while she makes up her mind.
Again, many thanks and I will post some pictures in the near future.
Nice try Ken... you bought it for your wife... right... OK, we're with you man
Some tires have a rib for 'wheel protection' to help avoid curb rash. You could just ask your wife to pay more attention to how close she gets to the curb....
You could just ban her from...not gonna go there!
The more expensive the wheels the more one needs to pay attention to the basics...like not scraping the curb! Three-piece is just another expensive solution...prevention is the cure, my friend!
I also had lowered her E55 and put a Carlsson front lip spoiler on it. The front spoiler would not clear a parking bumper and she never hit it, so she did learn how to take care of her car.
If you would like to lower the car, i would highly suggest using Steve. Im pretty sure he uses Star Diagnostics to lower the car. Just do a search and contact any number of people on the forum and im sure they will give solid reviews about him. If you are looking for overall mods, i would highly suggest going with klee who have different stages for their mods such as K1, K2, and K3. These will each vary in price. Also try out some tuners that arnt so popular on the board such as MKB. Ive heard good reviews about the.
In the end what i can say is Try klee or MKB for performence mods and from there on try some avus wheels or some HRE's.
How is Steve and where is he located?
You can e-mail him at info@euroteckmotorsports.com
Euroteck Motorsports carries almost every performance enhancing product and they also sell an insanely wide range of wheels from various companies.
Another company you should get in touch with is D2-Autosport @ sales@d2autosport.com
Experts in wheels and body kits.
Those two companies should be able to supply you with almost every modification you need.
But it adds weight and replacing the outer rim is usually just as costly as buying an entire new wheel. You have to send it back to the manufacturer for repair, and when it comes back, it has cost you 90-100% of a new wheel.
The ligtest wheels are single piece forged wheels. The absolute lightest will be magnesium wheels, second lightest, forged aluminum. Your factory wheels are 33 pounds each. My Renntech Monolites are under 20 pounds...
http://renntechmercedes.com/images/Monolite.html
and you can go lighter still if you have the cash by purchasing magnesium wheels. They are available from Neez, and Eisenhaus imports them. You are into the teens with those. www.eisenhaus.com
One thing with the monolites is that they are offered in an offset that will allow you to mount a 295 section tire in the rear with no rubbing, you can do a 295/255 staggered setup. No other wheel will allow that without body modification.
Right now, because of their rarity, you can get around $4500 or more for your factory wheels. That will get you a nice set of the real high performance stuff. Also be sure to check tire weights, I believe the stock tires are Mich PS2's which are excellent. If you change tires, don't go with something heavy, it will negate your benefits as it sits on the outer most part of the rotational mass and makes the biggest performance difference.
If you have TPS (Tire Pressure Monitoring System) on the CL65 make sure the new wheels can accept them. If you decide to do away with them, that feature can be temporarily disable through STAR.
http://www.brabus-online.de/prog04e.htm
Good Luck.
Good Luck.
If Kleemann, Renntech, Brabus, or anyone else does everything right, they should get in the vicinity of 650-675 HP out of that motor on a cool night. If they ask for too much from the turbos, then you have heat soak and a loss of power at higher RPM's, nevermind much reduced life from the turbochargers.
I have said it before many times... the limiting factor on this engine is the turbos. I spoke to Brabus a while ago and they were working on an upgrade that included larger turbos, as did Kleemann who eventually shelved the idea. Perhaps that's what this "S" conversion is, and I am curious about it myself. Someone should contact Brabus and find out. But if it isn't, and they are claiming 715 HP without internal engine modifications, it ain't happenin'.
Looking at this engine and its dyno sheets, its pretty clear that AMG has extracted most of what is safely possible from this motor. There is a much larger margin on the 600 engine, and that's why you get much more power from an ECU upgrade on that car.
The problem with larger turbos is that you have more lag, and you lose responsiveness. Something unacceptable in a car of this class. You also have drivetrain issues to contend with.
Bottom line: there is around a 10% safety/reliability margin on the motor that can be exploited. This is what these ECU upgrades are doing. If you want more, you have to change a whole host of parts on the car. As it is, I am absolutely sure that the lifespan of the turbos, and the drivetrain are compromised with any of these upgrades.
Good luck with your project, and you can still share pics of the stocks its always great to see the "work in progress".
If you need any assistance with the wheels, module, etc feel free to contact us
You have a nice website. Can't decide on wheels yet. Want to get the car lowered first then look at it. Most likely 20 in. by 9 and 10's plus. Not sure on the brand or style. HRE is 20 minutes from me, but never have purchased their wheels. To many of them in my area.
Have been buying the Carlsson UL wheels, but want to made a change. The car is black and has the grey center AMG wheels now on it. Not a bad look, but considering other finish options. Will give you call when I decide.
Nice cars! Let me know if you're thinking of selling the stock wheels from your CL65. I'm in Orange County. Thanks,
David M///
dtmiyasako@yahoo.com
If you decide to go HRE, we can provide them, if you decide to go another route we can do that as well.
Check your PM I have a really good idea I'd like to run by you regarding wheel finish!
