Vibration - New Tranny On The Way
Did yours suffer this or just the vibration?
Cheers, Matt
The main radiator and trans cooler are the same part. They are 1 unit.
BTW: The Valeo radiator issue is pretty much confined to the C, CLK, CLS and E class cars. But if there was metal in the trans then the Radiator issue is not your problem anyway.
Also metal in the pan, in this case, would be due to a failure of an internal component not due to burned clutch disks inside the trans most likely.
