CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Anybody looking for lowering module for the 215CL?
Old Dec 23, 2006 | 11:05 AM
Vic55's Avatar
Administrator
Creative Autoworks has mine on sale for cheap. I had it for less than three months. Not a bad deal IMO. Retails for 1700 but selling for 625 shipped. See link below, thanks. I think it will work on any ABC suspension.
Link to Carlsson Module for sale
Old Dec 23, 2006 | 12:06 PM
tkracing's Avatar
2003 CL55 stage 4 Renntech and 2006 CLS55 AMG
I will take it if it works for my CL 55 2003.
Old Dec 24, 2006 | 01:52 PM
Vic55's Avatar
Administrator
It absolutely will, same suspension. Call Creative on Tuesday when they open and they ship it to you or install it for you. 858 279 8900 is their number.
Old Dec 24, 2006 | 05:02 PM
jangy's Avatar
2015 S212
Nice price. Somebody will love it.
Old Dec 25, 2006 | 03:09 AM
Cutter's Avatar
2003 CL55
Why are you selling it and why did you remove it from your car??
Old Dec 25, 2006 | 12:56 PM
Vic55's Avatar
Administrator
For some reason my CL sits sky high and I want a super agressive look. I am looking for a different module that will drop more than 30mm which the Carlsson is optimal for.
Old Dec 25, 2006 | 02:24 PM
Cutter's Avatar
2003 CL55
Wow that's really unfortunate that you can not ADJUST the ride height for such an expensive piece. Maybe you should try something that is a lot more reasonably priced and will give you full flexibility to lower each corner of the vehicle to whatever height you like.
Old Dec 25, 2006 | 03:50 PM
awiner's Avatar
2003 CL55 AMG
You going to use the Klemann module Vic ? Renntech ?
Old Dec 25, 2006 | 04:31 PM
Vic55's Avatar
Administrator
The ABC has 3 ride height adjustments, none of which are suitable for my tastes. Dont you have the same ABC setup in your 2003 CL55? Its still one of the most advanced semi-automated suspensions out there IMO but it still has its fair share of issues. Oh and thanks for your thoughts on what I should do with my cars- I love your idea and might get rid of my 65 for a cheaper car just so I can lower it
The Carlsson does give you the ability to go up to 30mm more than the lowest height. As I mentioned before I want a super aggressive stance.
Old Dec 25, 2006 | 05:28 PM
Cutter's Avatar
2003 CL55
Yes I do have 3 settings as well. In the pic it's at the lowest setting. When raised to the highest setting its just a little higher then the lowest setting when it was stock. Can lower more very easily if I wish. You should really consider what I have to offer. It works great and you can make the car sit at whatever stance you like. You know the link. Don't wanna post it cause it will just get deleted until I become a site sponsor. All that the modules are doing is manipulating the computer with resistors.
I would definitely not sell your 65 cause you can not get it to the right height of your liking. Would work with you to make sure your very happy. I'm currently trying to sell mine to get a S65. If you have any questions send me a PM.
John.
Attached Thumbnails Anybody looking for lowering module for the 215CL?-clsmall.jpg
Old Dec 25, 2006 | 05:51 PM
awiner's Avatar
2003 CL55 AMG
The electronic modules actually offer some other options that manual links do not. For example, disabling the auto ride height lowering at speeds above 65mph.
Old Dec 25, 2006 | 06:21 PM
Cutter's Avatar
2003 CL55
If your worried about the automatic lowering at speeds above 65mph you can simply press the raise button once. I have never had a issue with rubbing. Just can't justify spending that much more money for something that does the same job as the links. The fact of cutting wires really discourages me from the module.
Old Dec 25, 2006 | 06:28 PM
Vic55's Avatar
Administrator
Tell me how links will work on the ABC- I know about how they work on the Airmatic.
Old Dec 25, 2006 | 06:39 PM
awiner's Avatar
2003 CL55 AMG
Just for clarification, I did not have to cut any wires the way I installed my module. I didn't even have to break any factory wire sheathing. Granted I have the Brabus module and it wires up to the ABC module a little different than some others by using a re-configuration of the wiring harness vs cutting and taping.
The main benefit of not having the car lower at speed is to keep the shocks from blowing out if you compress them enough at freeway speeds.
I have seen cars with the "Washer" or "Link" method more than once blow a shock from hitting a bump or dip at freeway speeds and having one or more of their shocks compress enough past the bump stop to blow them. This is the issue to be most concerned about about the "Washer" or "Link" lowering method and one the needs to be kept in mind when setting the ride height so that there is always 7-10mm of travel for the unknown at speed.
Old Dec 25, 2006 | 09:22 PM
Cutter's Avatar
2003 CL55
Awiner
It doesn't matter which way you lower the vehicle, Links or electronic module. You are changing the amount of travel in the Hydraulic strut period. If that concerns you, you should be the 1st to change out the entire system to shorter 1's. Much like regular cars without Airmatic. Could only imagine the cost of that.
I have lowered many vehicles with my fully Adjustable Billet Aluminum Links lower then mine and they have never blown anything.
Old Dec 26, 2006 | 12:35 AM
awiner's Avatar
2003 CL55 AMG
Awiner
Agreed, however, what I was pointing out, is with your method to use caution and leave enough height so that at freeway speeds when the system lowers the additional 25mm that there is still enough travel (7-10mm) to allow the suspension to compress within safe tolerances.
If you lower (slam) the car all the way down, then hit 65mph, the system will lower another 25mm. If you need travel at these speeds and it is not there guess what ? There will be problems eventually.
Old Dec 27, 2006 | 06:41 AM
Cutter's Avatar
2003 CL55
What is the lowest point??
I've seen cars when they sit for a long time and drop down to have the undercarriage almost on the ground. The lowest I have lowered a vehicle was a S55 with the front rim almost to the fender. He drove it for over a year like that with no problems and this guy really drove his car.
