CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
03 Cl600 Vs. 03 Cl55- Which Is Faster?
Old Oct 2, 2007 | 07:26 AM
02cl55amg's Avatar
CL65
the 02 cl55's 390tq aint cuttin it. planning on purchasing one of the 2 shortly. stock for stock which is faster in a straight line? hp is the same, looks like the 600 has 590tq compared to the 55's 515tq, but the 600 is heavier. want the most hp/tq for my $, btw both would be modded with a ecu upgrade(cl600) & pulleys/ecu(cl55).
Old Oct 2, 2007 | 08:55 AM
JAYCL600's Avatar
new balance
modded the 600 wins hands down
Old Oct 2, 2007 | 09:07 AM
Jaki's Avatar
E55 AMG + Mustang GT
+1
Much easier to mod a turboed car than a supercharged car.
Old Oct 2, 2007 | 09:46 AM
france2112's Avatar
2015 Mercedes-Benz CLS63 AMG S
I use to own an 03 CL55 stock and an 05 SL600 with ECU/TCU upgrade. The 600 stock pulled stronger then the 55 stock and when I modified the 600 forget it, one of the fastest cars on the road. Go for the 600 and get the ECU upgrade and new exhaust.
Old Oct 2, 2007 | 10:03 AM
DFW01E55's Avatar
'14 ML BT
My lightly modded '03 55 traps 115, Jay's modded '05 600 traps mid 120's.
That's pretty easy, right?
The cost to approach those speeds starts at 2k for either car.
I think that spending more than 5k triggers the diminishing returns process.
Old Oct 2, 2007 | 12:45 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
The only advantage my modded CL55 would have over a CL600 is that I don't have to worry about wheel spin in fourth gear :-).
If straight line is the main thing, CL600. The biggest benefit of the CL600 over the CL55, IMO, isn't necessarily what they do side by side at the drag strip but the effect on the street. The CL55 is "under geared", so the huge torque reserves of the CL600 enable it to pull away from same gear/same starting speed. The higher RPM limit of the CL55 basically can't be used to an advantage. I run shorter tires, but there just isn't any way to get up to what would be an effective ~3.06 ring and pinion where the CL55 needs to be.
Why not supercharge your current CL55? You've got the better 2.82 ring and pinion.
Old Oct 2, 2007 | 04:45 PM
02cl55amg's Avatar
CL65
its about what $12k to supercharge this car?(kleeman) thought about nitrous, but i heard its not that safe on these cars. i could get into a nice
cl55 for about $40k w/decent miles. a cl600 with amg sport, silver/charcoal is a tough find especially @$40k
Old Jan 15, 2008 | 04:58 PM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
And what if you add in the CL65 w215
Old Jan 15, 2008 | 07:10 PM
trumpet1's Avatar
2007 S600
I'd go 600 or 65. I have a 600 and it is Rennteched and has monstrous torque and speed.
Old Jan 22, 2008 | 11:11 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
I own an 03 CL55 and have extensively driven an 05 CL600
and can hands down say that even though I love my own car, the 600 is smoother faster and more powerful despite the numbers. the powerband is very well distributed vs the AMG which is somewhat jerky as with the supercharger engage and so forth. the turbos in the V12 spool quickly and hammer you but don't jerk like the supercharger clutch. Hands down 600 over 55 and I own it. Anybody who tells you different is selling them.
Old Jan 23, 2008 | 05:00 PM
Satan's Avatar
I can't afford
and the CL600 has that supple leather
Old Jan 23, 2008 | 07:30 PM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
And the alcantara headliner
Old Aug 31, 2008 | 06:51 AM
sick430's Avatar
CLK Cabrio
hey guys in the same boat right now the only thing that is drawing me to the 55 over the 600 are the AMG brakes which to say the lest are huge. i currently have the same brakes as on the 600 on my clk and just dont think they are big enough for the weight and speed of the 600. someone please tell me i am wrong or that i missed it somewhere and the 600 really do have the large 8 piston amg brakes.
thanks
liran
Old Aug 31, 2008 | 12:34 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
thanks
liran
The brakes on the tt600 are huge and does have the multi-piston brakes. You will not be left thinking they are insufficient.
Old Sep 26, 2008 | 12:41 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Apart from the engines being different does the 600 have the AMG body,
seats,suspension and brakes?
Old Sep 28, 2008 | 06:31 PM
Pronto's Avatar
2003 CL55
I'm curious if anyone here has heard of a mod to engage the supercharger off idle, rather than 2750 rpm? Also anyone changed the rearend to the higher numerical ratio for better acceleration?
Old Sep 29, 2008 | 08:31 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The super charger is LOAD and or rpm engaged. WOT=load= engaged.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 5, 2008 | 05:06 PM
JBrady's Avatar
Actually the only thing the same about the power is the factory "claim".
IMO, MB rated the 03 600's at 493hp so as to not eclipse the then brand new supercharged AMG 55s.
Ben Treynor put his then brand new S600 on the dyno and made 481rwhp That is DEFINITELY much more than 493hp crankshaft more in the mid to upper 500s. Obviously there is no comparison torque wise.
I understand that the chip upgrade quickens throttle response making the car not only much more powerful but also much more fun to drive. Treynor found 525rwhp on his S600 after the chip.
Old Oct 5, 2008 | 08:41 PM
Untertürkheim's Avatar
600 wins out of the box or modded.
Old Oct 7, 2008 | 07:20 PM
Pronto's Avatar
2003 CL55
Good to know. What I'd read about it, seemed to suggest it was only from that point. I'd assumed it was to maybe reduce the chance of wheelspin.
What do you think of your pulley mod? Would you recommend that as a first improvement or does something else give a better bang for the buck?
Old Oct 8, 2008 | 12:24 AM
dwalker011's Avatar
99 C5 FRC
Pulley won't do much alone. You'll get a decent torque gain but not much hp. If you do the flash with the pulley then you'll see some nice gains.
Cooling mods don't add power but they are basically a must. Your car won't use the power it has if it's running to hot. Cooling mods are cheap in the grand scheme of things anyway.
Old Oct 29, 2008 | 08:50 PM
red00lght's Avatar
2006 ML500
Not a perfect comparison, but I've owned 2 55 engine cars (E55 and S55) and a CL600. I just never fell in love with my 600.
It just seemed sluggish and heavy around town unless you really pushed it. Even then the turbos made it so quiet that I started missing the sound of a blown V8. It was stock btw so I can't speak for a modded car. I even took the CL600 to Renntech for a dyno and lookover to make sure something wasn't wrong!
The 55 engine sounded better and begged to be flogged. I would test drive both cars and go with your preference. Just my 2 cents!
Old Oct 30, 2008 | 11:05 AM
slavik's Avatar
g63
600 hands down!!
Old Oct 30, 2008 | 02:15 PM
Patentmat's Avatar
Totally agree. That said, the question asked was which is "faster" so in a straight line the 600. In the corners, I am really not sure.
Old Oct 30, 2008 | 04:04 PM
02cl55amg's Avatar
CL65
at this point, i might as well just buy a 65
