Nitrous Kit for CL55
I would not put Nitrous on any car that was a daily driver.
NOS is meant for drag cars that are only driven a qtr mile at a time-
Nitrous makes the fuel burn much too lean and hot- this will cause tremendous wear on your engine...
If the evo people say anything...just ask them if they realize that their in a lancer evo and your in a cl55...
Nitrous is an oxidizer. It chemically adds oxygen to the combustion chamber. You add fuel to compensate. Properly tuned, a sprayed car will still see 11.8 a/f or so at wide open throttle (the only time you would spray).
As for your hot comment, thats funny, because nitrous can actually be used as a chemical aftercooler. Of course higher cylinder pressure results in higher heat, but the added unburnt fuel cools the chamber just fine.
Nitrous is just like boost, if you don't tune for it properly, you will have an expensive paperweight. If you keep the a/f conservative and the timing in check, you should be just fine (assuming you aren't exceeding the mechanical limits of your rods, crank, etc.
P.S., what the hell are you doing street racing anyway? who cares about evos. If you really want to race every kid with a turbo 4 banger, buy a turbo'ed 03 mustang cobra and have at it.
My point is you WILL wear your engine out quicker with Nitrous than you will without it. DUH!!!
If you want a car to drag race in -buy a drag car. If you want a car to race -then buy a race car...MOST Mercedes Benz's are not made for this purpose....They are meant to be luxury vehicles.
I said MOST- there is the new Black Series of course! 8-)
