CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
'03 CL55 issue (whining noise / steering wheel vibration)
Old May 30, 2008 | 04:14 AM
leetski's Avatar
Bicycle
A whining noise with a slight steering wheel vibration that is present at very low speeds could be attributed to what?
Anyone experience this? My guess would be initial signs of ABC pump going bad. If thats the case, what would the dealership charge for a fix? Thanks guys.
Old May 30, 2008 | 08:06 AM
DFW01E55's Avatar
'14 ML BT
Low on power steering fluid?
Old May 30, 2008 | 12:18 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Thats the dreaded ABC pump impeller your feeling.
My CL500 did exactly the same thing. You can hear it whining with
rpm matching and a slight vibration in the wheel.
Get it to the dealer pronto. If it fails it will slam your car and cause
even more greif.
Hope you have warranty. Or your looking at about $ 3000.00 with the labor.
I think the pump is like $ 2400.00 with discount. List is $ 2900.00
Bummer.
Old May 30, 2008 | 01:17 PM
leetski's Avatar
Bicycle
even more greif.
Bummer.
What is interesting is that the symptoms you are describing only tend to show up after hard braking or so that was the case for the two times that I observed this unusual behavior. Thanks.
Old May 31, 2008 | 01:18 AM
leetski's Avatar
Bicycle
As a matter of fact, I was. There was some hydraulic fluid left but nowhere near enough to be within tolerance on dipstick. Besides an obvious leak, what else would cause the fluid to be wasted like that?
Now that I toped it off I'll monitor for any leaks.
Old May 31, 2008 | 07:28 AM
DFW01E55's Avatar
'14 ML BT
I don't know, but I'm in the same boat. Will be looking for leaks later today.
Old Jun 1, 2008 | 02:46 AM
Ramsey9000's Avatar
Cl55
It sounds like the Rack and Pinion is leaking ( mine cost $650 tax included)
I did mine at a place called Garo's Rack and Pinion in Miami. 305 558 1551 Tell him Hoffa sent you
Old Jun 2, 2008 | 09:42 AM
llcd's Avatar
2012 S550 4MATIC, 2007 R-350
What a coincidence.I was driving my car's wife last night which is a 2007 R -350 and had the exact same symptoms. When I went on a curve and stepped on the
brakes, I got this whiny sound and vibration in the stirring wheel... It seems to only happen when I brake hard. Then it went away for a few minutes. I am going to go and get it checked.
Old Jun 4, 2008 | 05:51 PM
leetski's Avatar
Bicycle
Let us know what you find out.
