CL55 amg stuck in park
Hi guys just bought a 02 SL55 amg which has got the same problem its stuck in park, I have not yet collected the car for fear of being ripped off bu the transporter company and the damage they may do,
as such I have not driven the car yet
My questions are
can this be done outside the sellers house is it a qiuck job
should i be worried about the condition of the gearbox other than that it wont come out of park are they troublesome or not
any advise would be great
is there any way of just yanking the lever back into drive just to get it home so as the work can be done there
thanks Rob
Ps was told by Mercedes that the selector on the CL55 was electronic and had no mechanical moving parts?
If you need to get the car going.... look very closely near the gear shifter and you'll see a small port that wil be big enough for a small flat head screw driver or a key. There is a relase button inside, so simultaniosuly(sp) put the car in drive while fishing for the button, but be aware that your brake lites may not work becasue the module I mention earlier is bad.
And please do not "YANK" it into drive.
Instead, I took the thing apart myself with standard tools and remvoed the plastic broken part. this is a well known problems with these cars.
see " Anyone Have This Stuck in Park Problem"
please see:
console removal: http://www.justanswer.com/questions/...-remove-center
shifter removal: http://www.JustAnswer.com/questions/1pevf-need-instructions-remove-w220?L=T
Internal plastic lever is there to prevent children from inadvertedly moving the gearstick lever out of Park. Removing the lever may cause your car to roll away down a hill with your kids inside.
Choose from original plastic or high strength aluminum. Repairs can be done by any reputable MBZ shop in about an hour or two. No need for recoding with Star Diagnosis.
Sorry If I insulted your intelligence, just trying to help.
Also like OCKlasse said, use the metal part to fix your shifter.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
It turns out a piece of a peanut got stuck in there and caused it to crack...
You can completely remove that little piece if you want, what it does is keeps the car from being moved out of park unless you have the break down and unless you have young kids not really necessary
Until i figured out how to fix it i would just park it in Neutral like a manual car but then you have to lock your doors manually since you can't remove the key fob from the ignition, you can also jiggle the shifter around a bit while trying to shoft out of park or remove the shift knob and tap the top of the column with a hammer while moving it out of park to get it in gear
I have a feeling I will have to cut off the gear shift handle to be able to fully remove the wood console because it's stuck in park and there is no room to remove it. I ordered a used one from the local MB yard here in the hopes of completely rebuilding my original one using the handle from the used one. I will install a new aluminum shift lever as well so no more stuck in park problems hopefully. I'll keep the forum informed of my progress with this and share any information I can gather that may help others with this problem.
I have tried many times and even resorted to using a club hammer and still no luck :-( My steps are as follows: I start the engine, put my foot on the brake and I can hear the solenoid click inside the shifter. I pull the handle across to the right and down hard towards the storage box in the console, then I hit the top of the handle hard with the hammer but there is no movement in it at all. The solenoid doesn't click if I just turn the key to on and press the brake without starting the engine.
Thanks very much for your reply.
