ABC ACTIVE BODY CONTROL DRIVE CAREFULLY??
Unless somebody has better ideas?
Thanks for all the replies.
Take care,
Brian
Take care,
Brian
Brian,
I didn't know about any CD ? Can I get one ?
http://youtu.be/IQ1eKddstxM
Pretty cool stuff.
I am going to go back and get the DVD for my R500 today. This DVD is really great!
same applies to fuel pumps
lol at "catastrophic pressure relieve valve"
Now I get the running dry part then if you continue to run the pump it will "eventually" give up the ghost. However if you read what some are writing on this forum the second air hits the pump, "BOOM!!!!!" it's a goner.
Upon replacement of the pump, you need to fill the reservoir and then pressurize it with a air hose to get the pump to start sucking and recirculating the fluid.
so yes- air "bubble", but it sticks in the pump and never leaves...
for that same reason when replacing pump you need to prime it as it does not generate enough vacuum when running dry to draw fluid on its own.
or a pulley. they are known to fail at a very high rate.
As far as the proper procedure goes, you will need a shop computer (DAS) to Rodeo and verify pressures as well as an air compressor to to prime/pressurize the reservoir if you want to follow Mercedes service exact steps.
I can print you out the procedure from WIS (Workshop Information System) when I get home. Alternately, you can search for a user names Oxygen. He posted the exact steps with pictures in the past.
Independent mechanic shop read all of the codes and said there were 5 or 6 including low pump pressure. Pump pressure tested OK. I have had a very slow seeping right rear shock for a long time which I ignored because it was so slow that it did not affect fluid level. Mechanic suggested replacing shock because it may be causing a domino effect throwing other codes.
Replaced shock with a rebuilt from Arnott Industries for $599. Have heard they are reliable and perhaps even better quality than OEM from Mercedes. After replacing shock, filters and flushing, no more codes or warning lights. I'm assuming minor leak of fluid was causing pressure variations.
Incidentally, I have had a low speed minor "clunking" that seemed to be coming from the left-front that nobody could diagnose. That went away with the shock replacement. Car is performing flawlessly -- just wish as many of you do that ABC problems were not always hovering over us -- the system is so complex and prone to failure. I got an appreciation for the magnitude of the system just by lifting that single shock --- shipping weight was 29 pounds.
With regard to the "bounciness" problems noted above and replacing accumulators to correct it, how many and where are they located?
Thanks,
Thanks,
4 units. 3 different part #'s
(1) Pulsation Dampener
(1) Pressure Relief
(2) Accumulators
compromising under pressure (Get It)
