Spark Plugs
the last plugs (closest to the firewall) are a b1tch. those plug connectors are also hard to remove as there is not enough room for leverage, but some mechanics gloves and colorful language usually does the trick.
you will need a flexible socket extension to reach most of the plugs.
make sure you mark which coil goes where as some of the cables from what i recall are different length.
good luck
alex
few cars
16 NGK BKR5EGP about 3bucks each single side electrode platinum plugs and you are good to go.Don't let anyone talk you into multi tip plugs the m113 hates them.Don't let anyone talk you into new wires,the wires you have will outlast the car if you don't abuse them(that is where the 17mm tool comes in handy).It gets access to the boot and uses gentle leverage to pop it off the plug.
pm me if you need more help.Replace your air filter at the same time(not Kand N) since you will have the air box and cover off anyway.
good luck
alex
few cars
thanks man. so its just like any other car. do you know why they charge close to G to replace them???????????
not recommend it unless you are reasonably skilled. My cost was £490
inc plugs. about 700 dollars at todays rate.Try to get a discount,quite often
they are prepared to lower the price.
