2008 CL63 tires - 7500 miles? Hankook V12 EVOs?
I have a 2008 CL63 with the 010 wheels.
I only have about 7500 miles on the car but I think it's time for new tires.
Question #1: Is that normal to need new tires at 7500 miles?
Question #2: Aug2009 Car & Driver just did a tire test: http://www.caranddriver.com/reviews/...mparison_tests
And they put the Hankook Ventus V12 EVOs in 2nd place (beating the Michelin PS2s on dry skidpad and just about matching on the wet skidpad).
The Hankook's are literally half the price of PS2s. What's your opinion on tires? Go with the Hankooks? PS2s? Originals?
Would only get factory-spec tires (Conti or Yokos) that have been calibrated/engineered vs AMG CL chassis set-up (and wt)
Many revered tire brands/models like PS2, though respected for dynamics on various cars like 3600lb 997TT, may not be optimal vs ~5000lb CL63/65 chassis set-up/wt
First set was good for 12000 miles and maybe after 9000 felt some slip. Second set at 7000 miles with no problems to date.
btw the weather here in Boston has been absolutely awful but when it rarely clears the car is a total blast. I have a Renntech ecu and it is tres formidable.
Can you tell me more about the Renntech ecu? Where do you go to get it? How noticeable is the difference? Does it void warranty? When I bring the CL in for service, do I need to worry?
Very noticeable performance increase. M mode with abs off is totally off the wall. I think that they claim 25-40 on both hp and torque. I've driven CL65 and 63 with Renntech ecu no difference. I can't comment on top end because I don't drive > 100 mph but in typical speed range nothing beats it, Have never lost a challenge.
I have the Hankooks, they last longer. I had the Perelli before and only lasted about 15K for the rear and 30K for the front. The other difference is that the Perellii's handle a lot better. They stick to the road.
Where do people get this BS.
What most likely is the case here is, your specific dealer has an agreement with Renntech where Renntech warranties and pays for any failures due to the ECU.
Btw, I love Renntech and they had super reliable products and warranty/support for my vehicle.
