CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
belt wrap kit for 04 CL55 AMG
Old Jul 28, 2009 | 11:47 AM
limeylight's Avatar
too many
Does anyone make these? I need one to stop the chirp when the S/C engages.
Old Jul 28, 2009 | 03:28 PM
SSM AMG's Avatar
2004 S55 AMG
VRP who is a sponser sells one.
Thing is I don't think its the engaging thats making the chirp. I believe its clutch. Maybe one of the pro's can chime in.
Old Jul 28, 2009 | 08:50 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Usually a new S/C belt will take care of that. I like the gates belts. Belt wrap would be a band aid and not the solution. IMO
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 29, 2009 | 08:11 AM
limeylight's Avatar
too many
Thanks. I have a call in to VRP but that kit is no longer on their site.
Old Jul 29, 2009 | 08:14 AM
limeylight's Avatar
too many
Going to try a Goodyear Gatorback belt on recomendation from Motorwerks here in Michigan. Will be an ecconomical fix if it works.
I'll let you know.
Old Jul 29, 2009 | 08:26 AM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
I think the belt wrap kit is the best solution for belt slippage.
Old Jul 29, 2009 | 08:33 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i will be removing one from my car sometime soon. it has only about 3k miles on it. pm me if interested.
Old Jul 29, 2009 | 10:10 PM
PLATINUM SPONSOR
2003 CL55
So if his car is bone stock , you still recommend that he he spend big $$$$ , modify the hell out of his pulley`s just to fix a "chirp" that was not there on a new car?
__________________
www.ultimatepd.com
Old Jul 30, 2009 | 12:05 PM
limeylight's Avatar
too many
Well, we put the Gatorback belt on and so far no more chirping so hopefully it will stay that way.
Thanks for everybody's input.
Old Dec 6, 2009 | 09:14 PM
silvercl55's Avatar
05 cl55 amg Renntech air box w/ K&N's LET 180 pulley & Tune, HE & Pump, 3'' Exhaust res/cat delete
what does the vrp kit actually do? I have a belt squeal also and they said it was one of the pullies and this is a common problem. would this fix that? and what are the benefits of replacing witht the vrp kit rather then just getting a new oem one.
