Tire Wear
CL500
Tire Wear
Do u guys get a lot of tire wear on the inside of ur back tires. my tires last 10K with regular driving and i have dot the ilignement done several times to no help.
CL500
2005 CL 65 AMG - TUNED
Will let you know
Sorry no details yet as I just got a 2005 CL 65 - fresh rear tires going on today - will let you know if I see anything strange over the next few months.
PLATINUM SPONSOR
Mine wear down in the middle, as they always are spinning.. I also adjusted the rear wheel camber/toe to take some of angle out of the tires. Need more straight line traction verses corning in this big car..
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
CL500
is it difficult to adjust the rear wheel camber at home or do i need to take it to the mb dealer? if its easy can u show me? Thanks
PLATINUM SPONSOR
I had an alignment shop make the adjsutment. They can hook thier machine up to set at the exact deg. you want or ask them..
__________________
www.ultimatepd.com
www.ultimatepd.com
CL500
PLATINUM SPONSOR
YOu can not buy camber or toe. They are angles. http://en.wikipedia.org/wiki/Camber_angle
Go to an alignment shop and tell them your tire wear issues and they should be able to adjust the camber/toe to reduce wear.
CL500
They also told me that the rear has to be adjusted before the front in order to ensure correct alignment. That was confirmed by the dealer and the AMG specialist I spoke with.
Had the indie check the dealer's alignment after it was performed and both readouts of the alignment were almost identical and within the AMG specs...
I actually got the dealer to have someone sit in the driver's seat while they were doing the alignment. I should note the dealer did the alignment for gratis, no geld. Thank you!
Not trying to be contentious. Just reporting.
