CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Brabus magic to feed air into the V12TT
Old Sep 12, 2009 | 02:40 PM
Oxygen's Avatar
W220 S65 AMG
Exclamation Brabus magic to feed air into the V12TT
Well Brabus recently dropped some vague details about their limited production, 10 unit, $875,000, Brabus EV12, based on the W212.
You can check out the pictures here: https://mbworld.org/forums/w211-amg/...2-biturbo.html
The article reads "...the E V12 features a 6.0-liter V12 biturbo bored out to 6.3-liters producing 800 hp and 1420 Nm (1047 ft-lb) of torque"
There is only a few pictures available, but I tried to brighten them up to reveal some hidden details...
The valve covers and the coolant line in the front reveal the all too familiar M275 motor. The intercoolers look to be revised/updated, the ignition module looks very different and the air intake setup is SICK!
Looks like the hood has has a ram-air like flap that draws air in through the grill and thats where the air filters mate up to the hood:
Old Sep 12, 2009 | 03:19 PM
MB_hunter's Avatar
AMGs
Once again crazy stuff from BRABUS!
Old Sep 12, 2009 | 03:32 PM
Brian GT PRO's Avatar
Former Vendor of MBWorld
C63 AMG Arctic w/ Stage 1 Tune, DoubleXX pipe, MCD-631X coming soon
Wow, that is really impressive
Old Sep 12, 2009 | 04:58 PM
V12Godspeed's Avatar
Your worst nightmare...
Only Brabus.....That is one killer set up...Wonder if they did anything with the TB..
Old Sep 12, 2009 | 11:25 PM
Thericker's Avatar
V12-Biturbo
Nice detective work man!!
Old Sep 13, 2009 | 05:39 AM
Oxygen's Avatar
W220 S65 AMG
Alright I found a few shots... this is ****ing AWESOME engineering.
Looking at the IC's... looks like the spliced two intercoolers together on each side, with the front facing ones actually being reversed and you have the back of the IC facing you and manifold thing in the middle that has 2 connections from each intercooler, dropping down into the TB. So essential this is 4 stock ICs working in tandem... not a bad idea!
LOVE those airboxes!
Looks like the
Old Sep 13, 2009 | 05:40 AM
Oxygen's Avatar
W220 S65 AMG
Looks like they also stuffed ABC in the W212... damn those guys are some serious engineers.
Old Sep 13, 2009 | 05:45 AM
Oxygen's Avatar
W220 S65 AMG
The boost pipe that is fed by the 4 intercoolers...
If you look to the left, you see the intercooler in the front overlapping the rear intercooler:
Old Sep 13, 2009 | 05:46 AM
Oxygen's Avatar
W220 S65 AMG
Looks like the ignition module was a little too "ugly" by Brabus standards so they outfitted it with a CF cover...
Old Sep 13, 2009 | 05:54 AM
Oxygen's Avatar
W220 S65 AMG
Old Sep 13, 2009 | 04:25 PM
Thericker's Avatar
V12-Biturbo
Dayum! I really like the way they thought this engine out, notice the trick IC piping, & (4) intercoolers wow! why would this be better than just (2) bigger IC's? Not trying to say I know better which I don't just curious on your input? + heat reflective material all over firewall etc..The CAI idea is indeed genius, utilizing stk boxes/local but removing tops, sealing OEM front air pipes off....
800 Crank HP equates roughly to 655 RWHP w/.18% loss. Wonder what she'd spit out w/100-105 octane Tune?
Paging Vadim let's make 1 on my SL NOW!!!!
Old Sep 13, 2009 | 05:08 PM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
you will need two-foot wide tires to put that power down. I guess they are going to make it a wide-body?
Old Sep 20, 2009 | 01:17 PM
Oxygen's Avatar
W220 S65 AMG
Alright here's some more pictures I've extracted...
Old Sep 20, 2009 | 02:40 PM
this car looks more idiotic every time I see it
but it does have a nice motor
Old Sep 20, 2009 | 09:44 PM
Viet_Amg408's Avatar
Pinto
i agree...damn this car is made to go fast and all the body kit is there to help it to be stable and arodynamic...but i can't figure out covering up the rear wheel do..? anyone have any idea?
Old Sep 20, 2009 | 09:51 PM
covering the wheel wells reduces drag and lift.
Here is an example of a "real" race car with covered rear wells
Oxygen's Avatar
W220 S65 AMG
Sure.. the rear wheel arch scoops up lots of air causing lots of drag.
shardul's Avatar
2003 W211 E55, 2003 W220 S600
very interesting
Old Sep 20, 2009 | 10:40 PM
i'm sorry you imagined that i wrote the word "lots"
Old Sep 20, 2009 | 10:52 PM
Oxygen's Avatar
W220 S65 AMG
I was replying to Viet_Amg408.. We replied at the same time.
Old Sep 20, 2009 | 11:11 PM
oh,i see, my mistake
Old Sep 21, 2009 | 09:40 AM
What I find very interesting is that VRP has the exact same set up if you think about it. Filters, Bigeers IC's and Tune. Viola 800+ HP, Somehow, someway it is weird to say VRP came out with it first..., I am sure they brabus probably had it in development stages, but hats off to both tuners.
Old Sep 21, 2009 | 10:23 AM
Oxygen's Avatar
W220 S65 AMG
Well don't forget that this motor displaces 6.3L and has new crankshaft, cams, heads.
Old Sep 21, 2009 | 01:42 PM
Wonder which cams are they using, profile etc? Those should be interesting...
Old Sep 21, 2009 | 01:51 PM
Oxygen's Avatar
W220 S65 AMG
We'll never know.
The thing that I like about Brabus is that they do not mess with AMG stuff and that they try to use as many Mercedes OEM parts as possible... example using 4x Mercedes-Benz OEM (BEHR brand) intercoolers and factory HE's, etc..
