CL55 STAR Inspection repair bill
- SRS light on. Cleared codes if returns further diagnosis is required. $120.00
- Checking of ABC system, L/F Strut (boot torn and play in top mount and is leaking) $2260.00
- Recommend ABC System Flush and replace filter $653.00
- Replace Both drive belts $240.00
- Front brake pads are down to metal to metal replace pads/rotors $1549.00
- Rear Pads/rotors replace (1mm close sensor) $640.00
- Rear tires bald $1023.00 Bridgestone Potenza P275/40R18 99Y
- False reading Oil level warning coming on replace oil level switch $463.00
- L/F Ball joint 2-3mm movement (replace by next service) $409.00
- Wiper blades smearing $133.20
Total Bill: $7490 + Taxes CAD
Are these prices reasonable from the dealer? Or should I shop around and make some stuff DIY?
- Flush ABC system (done)
- Strut boot replaced, strut is FINE and NOT leaking.
- Belts fine
- Front pads and rotors replaced, rears rotors fine but pads replaced.
- Oil level sensor is FINE, level checked manually and through SDS. Working fine.
- L/F tie rod end replaced.
- Wipers replaced.
Total was just under 2 grand, including the new tires.
- Belts fine
- Wipers replaced.
Did you ever get that SRS issue sorted out? I've been looking into that for my S. Research makes me think either defective seat belt tensioner or, more likely, the seat buckle itself goes bad, so the car is confused as to whether you're strapped in or not. Any help here is appreciated.
Also, glad you got some sanity on the above repair.
Best,
maw
- Belts fine
- Wipers replaced.
Thanks for the help Viet. I'll update all.
maw
- Belts fine
- Wipers replaced.
What dealership gave the inflated estimate and who gave you the truthful estimate?
Thanks.
maw
maw
