CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Radio, Nav, wont turn on
Old Apr 16, 2010 | 12:54 AM
sheldon41's Avatar
cl55
2005 CL55: Power to Radio, Nav, etc. powers off and on intermittenly.
Any help?
Old Apr 16, 2010 | 08:54 PM
silvercl55's Avatar
05 cl55 amg Renntech air box w/ K&N's LET 180 pulley & Tune, HE & Pump, 3'' Exhaust res/cat delete
I'm having the same problem right this sec. Does it work at all can u use anything nav, radio, cd?
Old Apr 17, 2010 | 11:41 PM
NISMO240SSX's Avatar
CL63 N/A 2008
I've had this same problem for a few weeks, still no soln.
Mine will power on when car turns on, display the emblem, boots up then displays "System Unavailable" and power off. No radio, nav, sat working.
I have emailed radioman repair and they can fix certain units. Haven't had the time yet.
Old Apr 18, 2010 | 05:37 PM
silvercl55's Avatar
weird mine is doing the same thing.. did they say what the problem is? why all of a sudden are we all having this problem.. i searched on here forever and havent found much on it now all of a sudden there's 3 of us in a matter of 2 weeks witht the same problem.
Old Apr 21, 2010 | 09:49 PM
CL63 N/A 2008
I know what you mean, I've also looked around. Seems the guys over the pond have more knowledge in retrofitting and trouble shooting it, but no luck.
I've hooked up to SDS and is shows an open MOST ring and does not recognize any of the components (nav, sat, etc). Then we dug into the back of the head unit from the vent/speaker thing in the center of the dash. There is no optical output from my unit.
Any ideas on how to pull out the unit? I'm okay with sending it to radioman.
PS Sorry for the delay, forgot so set the notification.
Old Apr 21, 2010 | 10:22 PM
silvercl55's Avatar
Radio man charges alot for the radio. Have u asked them a price to rebuild it thinks it was around 800-1000. I have a company who charge 100-200 to rebuild the head unit. Who checked out the unit for u? Is there a way I can check to see what codes I have without going to the dealer?
Old Apr 21, 2010 | 11:39 PM
CL63 N/A 2008
I had a local shop in LA look into it, Benz n Beamers.
I was able to get the codes via a simple SDS scan. You should be able to pull that from a friendly service writer or 1 hr diag.
I haven't gotten pricing, as they need the barcode info from the bottom of the head unit. Still trying to figure how the whole thing comes apart.
Old Apr 29, 2010 | 08:52 AM
silvercl55's Avatar
Any luck getting your command fixed?? I'm still driving down the road with nothing lol. I'm bringing it in the shop this weekend to deal with this nonsense I can't take I anymore!!
Old Apr 29, 2010 | 11:37 AM
Nightflyer's Avatar
03 CL55
CD Player/ AMP and optics for sale
If you guys are having trouble with the CD changer, AMPs or optics I have one in excellent condition for sale. It even has the bracket that holds both Amps and CD player. If interested shoot me a reasonable offer and we will go from there. Good Luck.
Old May 10, 2010 | 03:49 PM
silvercl55's Avatar
I had mine looked at and it's the audio gateway unit I believe that's what's it's called. It's next to the Bose amp. We tried one he ha laying around and it worked instantly. Now I need to get one does anyone have one for sale??
Old May 15, 2010 | 05:12 PM
Sathinas's Avatar
S65
I bet you're suffering from a bad fiberoptic emitter on that Audio Gateway... or even just a bad fiberoptic connector.
Old May 16, 2010 | 11:21 PM
CL63 N/A 2008
Can anyone confirm that the optical signal starts at the Command head unit? During diag I was told there was no light/signal output.
Just wondering before I trying repairing or buying a ebay unit for testing.
Old May 16, 2010 | 11:27 PM
Sathinas's Avatar
S65
I would think it starts in the trunk at the hub, but the head unit should also have an emitter that it sends data back to the hub and across the network in general.
Old May 17, 2010 | 11:08 AM
silvercl55's Avatar
It is the audio gateway. The head unit sends the signal back through the trunk. Now my problem is finding one to buy. I called Mercedes and to gt a tefurb wholesale it's $129 which is a great price but they said it's for a 04 and under. It makes no sense to me why it wouldn't work espically when I tried one from another car. Does anyone know if there is a difference between the -04& 05-06 since they supposably don't make a refurb for a 05-06 unit.
Old Mar 12, 2011 | 02:38 PM
CL63 N/A 2008
Fixed!
My issue has been resolved, it was the Audio Gateway. Cost $250 @ dealer w. core charge.
P/N A2208702989
Looks like the size of a 1/2 din radio without the face, goes into the trunk opp the battery.
Old Dec 5, 2011 | 11:57 PM
hyelifeCL's Avatar
CL600, E30 325i Previous ride CL55 2004
I have the problems. Replaced audio gateway that i got from the dealer. Worked for few hours and same thing again. I guess it is the head unit. Any ideas?
It will work sometimes but rarely, like once a month.
