How do you disable the TPMS? I have access to a STAR system but cannot figure it out. My car is a 2008 CL550 and put 22" forgianos on it and would prefer not to have to buy the sensors. I get a warning light at start up and after driving for approx 30 minutes, I get a No SENSOR warning. Any input would be appreciated....
You need to change the coding in the instrument clustor to turn off TPMS. Pre-SCN this is easy to do. You late model would require a SCN change (change of data card then subsequent re-coding). It may be possible if you have developer mode on you SDS to manually change the coding, have a look around and see what you find. You will only have to change the instrument clustor, no need to change anything else.
Hi- I'd like to disable the TPMS system on my 2006 W220 which provides a useless and annoying "warning" that causes me to have to "reset" the screen multiple times per drive. I don't want to spend the approx. $200 per wheel to fix what is likely an old battery. I have seen this issue mentioned a few times but no satisfactory answer. Help . . . Anyone!
Mine is disabled. The dealer did it for me.
Here is the correct way to do it. Go into intrument cluster - control unit adaptation - Tpm - select all settings to turn off. Now that will work and get your TPM warnings off the cluster but to do it properly now go into the CGW - control unit adaptations- all coding- and remove the TPM system from the coding now the car will not look for it and when diagnostics are run its not showing up with error codes.
Former Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
iTrader Positive Feedback100
iTrader Feedback Score(1)
- Vehicle(s) I drive2003 W211 E55, 2003 W220 S600
Liked:295 Times in 244 Posts
Quote:
Thanks,
Andrew
You need das to do it. Originally Posted by MrFewzn
Kindly tell me what dealer turned off your TPMS - I'm in San Diego...Thanks,
Andrew
Set TPMS to inactive in the CGW and IC and also I the TPMS control module
You can make a TPMS pipe bomb if you have all the sensors.
http://www.scionlife.com/forums/showthread.php?t=144818
http://www.clublexus.com/forums/is-s...pipe-bomb.html
ExploreFormer Vendor of MBWorld
shardul
close
- Join DateMay 2008
- LocationHouston
That is cool!Originally Posted by KENCO
You can make a TPMS pipe bomb if you have all the sensors.http://www.scionlife.com/forums/showthread.php?t=144818
My DAS doesn't have an option to set TPMS anywhere, where can I find it? 2009 w216Originally Posted by shardul
You need das to do it.Set TPMS to inactive in the CGW and IC and also I the TPMS control module
