CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
03 Cl-55 may need "new hydraulic engine mounts"??
Old Oct 29, 2010 | 01:00 AM
jkirk's Avatar
08 CL-63 AMG
Has anyone had this done? My car has 40,000 miles and new engine mounts may be needed??
Thanks in advance.
jk
Old Oct 29, 2010 | 09:23 AM
SLCL's Avatar
CL55, SL500, E350
Comon issue. Mine replaced at 30K miles (along with tranny mount as well).
Old Oct 29, 2010 | 10:56 AM
Patentmat's Avatar
I replaced mine when I redid my suspension, at around 90K. It was not 100% necessary when I did it, as they were only partially collapsed, but since MB had my car for a week I went ahead and told them to do the mounts as well.
Old Oct 29, 2010 | 12:40 PM
jkirk's Avatar
08 CL-63 AMG
Thanks much for your reply's..
Old Nov 4, 2010 | 10:19 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Mine were bad at 40K..Those hard drag strip launches did not help them much..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 5, 2010 | 05:17 AM
paul65k's Avatar
2016 E250 Bluetec 2002 CL55, 2000 430CLK Cab
Mine were bad at 70K miles (6 years). The years may be more applicable than the mileage??
Old Nov 13, 2010 | 11:36 AM
airtony's Avatar
2012 CL63AMG
Take off
I would say that its the way you take off that puts most strain on your mounts not miles or years.
Old Jun 1, 2011 | 03:05 PM
Yawnald's Avatar
CL55 AMG
How much do these mounts tend to cost?
Old Jun 1, 2011 | 04:48 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
mine went bad at 60K
Old Jun 1, 2011 | 05:16 PM
sunpointair's Avatar
2003 CL55
How do you know when they need replacing ?
Old Jun 2, 2011 | 12:22 PM
2003 CL55
Seriously, Will the motor lift enough that the fan will hit ? I didn't realize that the mounts were hydraulic or that this was a common problem with theses.....
Old Jun 7, 2011 | 02:31 PM
grane's Avatar
GLK350, SL63 AMG
Thanks in advance.
jk
Search on the site under your model for factory Bulletins. As I recall there was a Bulletin on these, so you may be able to have it covered gratis. Make sure the tranny mounts are inspected also. The dealer may need your VIN. Have this Bulletin info in detail before you approach the Service writer!
Old Jun 8, 2011 | 02:22 AM
02cl55amg's Avatar
CL65
i just bought an 04 cl500 yesterday. it has 83kmiles on it and was told the engine/tranny mounts will need attention prob by the end of the year
