cl65 ECU upgrade
https://mbworld.org/forums/s55-amg-s...r-s63-amg.html
It's night and day.
Sounds awesome.
On the W215 cars, the TCU software upgrade is done to the physical TCU. We do these on an exchange basis, where we ship the TCU and the Block Tuner to you, and you ship back the factory TCU.
James@ACG
First, Besanko admits that the benefit of tuning certain cars is low, and that it's up to the owner to decide if it's worthwhile. This is nothing new, and it doesn't make him a cheat. Plenty of modifications (air filters, exhaust, etc.) offer only marginal power gains on certain cars. RENNtech charges several thousand dollars for air filter housings that makes only a few horsepower. Dinan offers BMW M3 tunes, even though the increase is minimal. Reputable companies do this, and it's called capitalism. If you don't think it's worth it, don't buy it.
Second, the interviewer seems to be suggesting that tuning is useless on a turbo car, because you can simply slap on a Manual Boost Controller (MBC). On the list of things I want to do to my Benz, this is followed only by "redo the paint with sandpaper and the body panels with a sledge hammer." I remember every time I saw "I blew my engine" on a Subaru WRX board, it was followed with "I installed an MBC from eBay." How do you account for Part Throttle Full Boost without tuning? You're making no adjustments to your timing map, and praying the stock ECU can guess and provide enough fuel to stop detonation? If you have a turbo car and you raise boost, you need tuning more, not less.
How many tuners do a full EPA testing cycle for a tuned car? I've never seen a single one. I don't know why the interviewer is expecting Powerchip would. Did the interviewer do a full EPA test when he installed the MBC and raised boost? Is his ECU dumping gas because the boost pressure is way out of parameter, and it's desperately trying to lower intake temps to prevent detonation? Is that burning his catalytic converters out, so they no longer filter NOx or CO?
Just because Besanko doesn't write the software himself, it doesn't mean the software is bad, although this is the first thing the interviewer tries to impress on you. How many managers hire talented people to produce things they don't know how to do themselves? Do you think Steve Jobs knows how to modify an ARM chip design to include a GPU and then write it to silicon to make the new A4 chip used in the iPad? Probably not, but he hired people who do, and now they can barely keep them on shelves.
The interviewer seems to imply that because Powerchip doesn't own a dyno, something is wrong with their tunes. Dynos are expensive. It makes sense to share and outsource. Even a company that does custom one-off tunes for maximum performance won't run their dyno 24/7. A company like Powerchip that does mostly off the shelf tunes will generally dyno a particular model of car once, create a map, put in a margin of error (to account for manufacturing differences and various mods the car might have), and be done. They are even less likely to need a full time dyno, when they can simply rent one for a few hours when they have a new model of car to tune.
Obviously, they don't have a engine dyno. Tuners don't have these, manufacturers do. Tuners care about wheel horsepower, not crank. Manufacturers need them for emissions, rated horsepower, and other calculations that go onto the window sticker. Tuners, no matter how reputable, don't ship you a new window sticker when you buy their exhaust, intake, or tune.
A more appropriate question would be "do you follow up dyno testing with road testing?" Who cares if they own a dyno, if they can easily rent one. Dyno testing is great for getting close, but a car, particularly an intercooled one, behaves differently when wind speeds vary and load is dynamic, versus when it's sitting on a roller with a fan blowing on it. The interviewer wants to hear if they own a dyno. I'd like to hear if they do a road dyno with a knock sensor, EGT probe, and wideband O2 filter, monitoring RPM, injector duty cycle, O2 mixture, EGT, and timing advance.
In summary, I would not base any purchasing decision on that interview.
If we were talking M3's, this would almost (but still not) make sense. The M3 is already pretty squeezed, as Powerchip even admits. But the topic is about a CL65 and the last post from Powerchip was regarding a CL600. I don't think you can name another car ever made with so much potential from just a tune.
Trying to massage big gains out of an already-tuned/optimized NA car, however? Mostly futile.
Find yourself a good company, and if you want un-restricted speed, and a few extra hp/tq, then go for it.
oetuning
Thanks for contacting me. There are a few ways of doing this. You can
> remove and send in your ecu or if you do not want to remove your ecu I
> have a product called E-Z Flash that allows you to flash OBD2. E-Z
> Flash gives you the ability to have 2 map settings that you can switch
> between with the ease of a flash. E-Z Flash if yours to own and costs
> and additional $400.00. The cost of the tune (separate cost) is
> $1995.00 with complementary ground shipping. Turnaround time can be a
> s little as 2-3 days if overnight shipping is used. The gains to be
> expected are +50-65whp and +60-85wTq. The top speed limiter is also
> removed. I hope that I have answered all your questions. Please let me
Here he is promoting a tune from OE, even mentioning discount pricing: https://mbworld.org/forums/c-class-w...y-w-dynos.html
And here he is also suggesting to Google "Powerchip": https://mbworld.org/forums/4394616-post173.html
I think I provided enough examples of the logical and technical fallacies of the article you posted. I don't see anything else to cover here.
As for being a fan boy, I never said anything to promote Powerchip. I have no experience with them. If you have experience, instead of posting a misleading and flawed article, how about being forthcoming? All the rumors (his former employee said this, he stole that, etc.) are irrelevant. That's for the various parties and their lawyers to figure out.
Does the tune work or not? If you're a current or former customer, with no other motivation, then post that. Did you get a tune from Powerchip that didn't work?
I posted not because I'm a fan boy, but because the article was flawed, it's unfair both to Powerchip and other tuners, and your attack is obviously either biased or misrepresented. Clearly your beef with him has nothing to do with the content of the article you posted.
