Options on lowering?
#1, via DAS at your dealer. Chances are 99% of dealers won't do this for various reasons.
#2, electronic lowering module. Kleemann, etc. makes these. Pricey but work well.
#3, Lowering brackets (Trick the height sensors in thinking the car is higher than it is in order to lower it self). Works but isn't as adjustable as the electronic module. A lot cheaper however.
What will the lowering module set me back and how does it work?
Kleemann and Brabus both make them.
thanks in advance
what steps do the Dealers need to do in order to lower the car electronically vis DAS i have a tech at a local dealer that may be available to lower the CL but need proper step by step directions
thanks in advance
In Europe however, the CL sits a little lower there. Our US DOT regulations require a higher height setting for the front bumper.
I would be interested on the DAS configuration as well.
Oak
I know Classic Cars in Atlanta can do it.
But, does the ROW setting accomplish the same result as the more involved recalibrating of the sensors method? The ROW lowers it 1/2" or so. Does the other way lower it further?
I'd also be interested in more info on the sensor brackets, if anyone has any (like who carries them).
Thanks,
Dave
