CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55k Belt Squeak on Cold Startup...ABC Pulley?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Dec 4, 2011 | 08:52 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Do you guys think it' just the serpentine belt or could it be the ABC pulley as well? I've attached a youtube vid of what it sounds like (listen about 20 seconds in).
It only squeaks on a cold startup. Once the car is fully warmed up it goes away. I recently had a coolant issue, and believe some coolant may have gotten on the belt. The sound only appears to be coming from the ABC area.
Thanks in advance!
http://www.youtube.com/watch?v=AyWxAa4jbaI
Old Dec 4, 2011 | 08:56 PM
OCKlasse's Avatar
MBworld Guru
By the way, I sprayed some WD-40 on the belt away from the pulley and the sound stopped for a few seconds, then resumed.
Old Dec 4, 2011 | 09:30 PM
awiner's Avatar
2003 CL55 AMG
I had this same issue and lived with it for several months. I told a friend whom is a MB Tech and he recommended taking a wire brush and "De-glazing" the back side of the belt and all smooth pulleys.
Once I did this, carefully with the engine running, the sound went away.
Might be worth trying and seeing if this fixes your sounds.
Old Dec 4, 2011 | 10:49 PM
OCKlasse's Avatar
MBworld Guru
Thanks for the reply! Already bought a new belt, so hopefully that a thorough cleaning of the pulleys will do the trick!
Old Dec 5, 2011 | 01:00 AM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
can you give a little more detail on this process? I'm not sure quite what you mean by "de-glazing" but I def want to try this...
Old Dec 5, 2011 | 02:54 AM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
The squeak sounds inconsistent. OCKlasse, does the squeaking go away when you turn steering wheel and reappear right after?
Old Dec 5, 2011 | 05:59 PM
dtohio's Avatar
05,cl65;33ford3wc.
Hi, alternator may be charging more at start up, but i think you have other issues. Any antifreeze or other contaiments on the belt can enhanse slip. A new belt is a good first gess.
Old Dec 5, 2011 | 08:23 PM
OCKlasse's Avatar
MBworld Guru
Hey, yeah I did get some coolant on the belt, so it's being changed with this week.
Old Dec 5, 2011 | 08:24 PM
OCKlasse's Avatar
MBworld Guru
Just gets louder with acceleration. Turning the steering wheel does not affect it. Completely goes away when the engine fully warms up.
Old Dec 6, 2011 | 04:12 AM
iAMGod's Avatar
996tt
Had this on my SL55 - just ignored it - would go away when it heated up - I think every single 55 has this problem at some stage.
Old Dec 8, 2011 | 11:29 PM
benz_addict's Avatar
V12TT
Had the same noise. I lost count whether if it was the SC idler pulley, or main idler, tensioner or the ABC pulley. BTW the ABC pulley is replaceable and there is a separate part number. Some noises go away when it's fully warmed up but some noises stay but I think it's the main S/C clutch making the sound now. Oh well.
Old Dec 11, 2011 | 02:27 PM
OCKlasse's Avatar
MBworld Guru
Thanks. I'm getting the new belt put on this week. We shall see if that alleviates the issue.
Old Dec 16, 2011 | 09:13 PM
V12TT
Love the wheels and the drop! Module or links? And that grille is starting to grow on me
Old Dec 17, 2011 | 01:56 AM
OCKlasse's Avatar
MBworld Guru
Modified factory links
The grille is growing on me, too. It wasn't my choice...
Old Dec 17, 2011 | 09:53 PM
grane's Avatar
GLK350, SL63 AMG
Replace both belts and the plastic idler pulleys whether they seem ok or not. Spin the other pulleys with the belts off to see if they make noise. If they do replace them.
Keep the old parts and throw them in a box of spares in the trunk.
Old Dec 31, 2011 | 09:30 AM
Amgandm's Avatar
Cl55 amg
I have exactly the same squeak on cold start, did it help since you change new belts?
Old Jan 1, 2012 | 06:58 PM
OCKlasse's Avatar
MBworld Guru
Not yet! My tech had time to do other maintenance work for me, but we have not gotten to the belt yet. Hopefully within the next week or two I can finally get this done!
Old Jan 2, 2012 | 03:00 AM
559cl55amg's Avatar
2003 cl55 amg, 2008 Range Rover Sport SC
Hey I have the exact squeak. I sprayed some grg door lub and it went away. I usually spray every 2 weeks.. Idk what it is. It's the pulley for sure. No biggy
Old Jan 2, 2012 | 10:36 PM
C-rod's Avatar
2014 ML350 BlueTec.
Thumbs up Hello...........
Though I do not own the same vehicle............ I had the same squeak on my 2011 ML550, It was only on start-up and it went away after 3-4 minutes..I brought in the vehicle last week and it was the V-Belt....They applied belt dressing and the squeak is gone..Part# 000-989-84-51 SILC/BELT PASTE. I hope that helps....
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
