One slick rear tire? How come just one?
) and I monitored the air very closely keeping it at 35 to 40 psi (cold) all the time. I do have a really fun curvy road I take for a few miles every day at some speed (no squealing of course, but some pushing now and then).So why just one bald tire?
35-40psi of air pressure in your tire when its cold is too much. As you drive, your tires warm up and the air pressure rises. I've seen mine rise up to 4 psi. That is why you are buring up just the middle of the tire. Try lowering the tire pressure a couple psi on your new set and monitor them.
R.K.
I guess I'll put 20 psi in that one and ride on the edges for a while! (JK)
Also, back to the original question, How come just one? Does the differential have a preference or something? Am I turning hard one way too often?
Just one because of the rear diff. You will notice that even with your traction control on, usually one tire will lose traction and you car goes sideways a bit. That is why guys upgrade their rear diffs so that both wheels spin at the same time. No single tire fire anymore.
R.K.
Some of them you can but it involves dismounting the tires, swapping them, and then remounting and balancing them. Some tires have "outside" and "inside" written on them. On those, you would be screwed.
R.K.
on tire pressure- what do the door label says? on the r230 sl65 it says 37/39 psi front/rear.
worn in the middle means overpressure... no question about it though...
After all this, I noticed that I drove rather gingerly to work today. Depressing. I'm sure I'll get over that.
R.K.
So I have two of these coming for the same price and Y rated! The more I looked at the other rear tire the more I could see that it wasn't that far from bald too. So WTF, just get a pair. http://www.onlinetires.com/products/...0+101y+bw.html
