CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ANOTHER Wheel Question!
Old Aug 16, 2012 | 05:28 PM
CharlestonN's Avatar
03' CL55 AMG
I've looked around and can't seam to find a definitive answer to my question
I was recently quoted on a set of wheel with the below specs for my 03' CL55 and i want to know if this sounds right, i'm going for a fitment that is flush with the top of the fenders without needing spacers and i plan on lowering but i'm not worried about a little rubbing hear and there during everyday driving
Front - 20x9 +20 Offset, 245/35 Tires (Hankook Ventus V12)
Rear - 20x10.5 +20 Offset, 285/30 Tires (Hankook Ventus V12)
Any advice would be greatly appreciated! Thanks in advance
Old Aug 16, 2012 | 06:23 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Let me know what wheels you're looking to get and I can let you know!
Old Aug 16, 2012 | 06:35 PM
03' CL55 AMG
P.M. Sent! Thanks!
Old Aug 16, 2012 | 10:50 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Wrong offests by a wide margin. They are going to stick way out from the fender.
Old Aug 17, 2012 | 04:05 AM
559cl55amg's Avatar
2003 cl55 amg, 2008 Range Rover Sport SC
Offset wayyyyy to low. I once did 25+ cls fitment. They stuck out 1/2 inch. For flush id probably consider 32et - 38. The lower to 32 the more aggressive and more rub. Hope this helps.
Old Aug 17, 2012 | 08:49 AM
biker349's Avatar
cl600
my cl600 with staggered wheels is i believe 44.
Old Aug 17, 2012 | 11:06 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
OP, not going to happen unless you are doing a widebody.
R.K.
Old Aug 17, 2012 | 12:16 PM
Or you can get coilovers and oni camber it all japanese style like this
You have a PM back also
Old Aug 17, 2012 | 01:22 PM
03' CL55 AMG
Haha, well i definitely DON'T want it to look like that!
I am looking for a fitment as close as possible to this CLS55
Old Aug 17, 2012 | 01:27 PM
That does look amazing!
I feel like those front tires are stretched with tiny sidewalls, it looks like it's sitting on the wheels up front haha!
Old Aug 17, 2012 | 01:49 PM
03' CL55 AMG
They look a little thicker from the side
Old Aug 17, 2012 | 01:54 PM
Yes, beautiful!
Old Sep 11, 2012 | 03:19 AM
Hakop's Avatar
2005 CL55
2005 CL55 tire fitting
Can any1 help me out with tires for my 2005 CL55 I only tried the rear wheel but the tire is sticking out the fender a lil bit about an inch or inch N a half the rims are fender flush the rim is sitting perfect only the tire is the problem any1 know what's the best Pirelli PZERO tire size for a fender flush offset wheel? I was thinking of going 275 in the rear
Savini Forged SV-10 With Pirelli PZero Tires
Front 9.0x20 245/35/20
Rear 10.5x20 285/30/20
Old Sep 11, 2012 | 03:24 AM
559cl55amg's Avatar
Sounds like your offset is too low. This is why it's very important to run the correct offsets. The only wy to make the wheel tuck in and still rub are 255's in the rear.
Old Sep 11, 2012 | 11:46 AM
radride's Avatar
You need to speak english man. You are making absolutely no sense. If you have a 285 on a 10.5" wide rear and the tires are past the wheel, your rim or wheel is not 10.5" wide. You probably have a 9" wide rear wheel. I run 305's on a 10.5 and the tires don't stick out past the wheel. Something doesn't add up.
R.K.
Old Sep 14, 2012 | 12:06 PM
Hakop's Avatar
2005 CL55
R.K.
it's a 10.5 fender flush offset the problem is the pirelli tires there different I think it's cuz they have the lip protection
Old Sep 14, 2012 | 01:53 PM
radride's Avatar
I have P-Zero's on the rear of mine and no issues:
R.K.
Old Sep 14, 2012 | 02:14 PM
Hakop's Avatar
2005 CL55
R.K.
What's Ur offset rim width and tire size exact
Old Sep 14, 2012 | 02:46 PM
Hakop's Avatar
2005 CL55
And if the one in the pic is urz mine is gonna be dropped more than urz
Old Sep 14, 2012 | 03:16 PM
radride's Avatar
It won't matter what my offsets are due to mine being a CL65 which has completely different offsets than the CL 500/55/600's.
My wheel size are 20x9 in the front and 20x10.5 in the rear. The car is lowered 2" in those pictures via lowering module. That's my driving height as well.
R.K.
Old Sep 14, 2012 | 03:38 PM
Hakop's Avatar
2005 CL55
R.K.
Is urz fender flush and u have no rubbing issues?
Old Sep 14, 2012 | 03:45 PM
Hakop's Avatar
2005 CL55
And Ur tires r not the same as mine urz r not jus pzero this my tire check the tread pattern
http://m.pirelli.com/mobile/ww/en/car/sheet/pzero.html
Old Sep 14, 2012 | 05:40 PM
radride's Avatar
You don't have the tires you posted because they don't come in the size you said you have. Yes my fenders are flush and no I don't have any rubbing issues.
R.K.
Old Sep 14, 2012 | 07:02 PM
Hakop's Avatar
2005 CL55
R.K.
That's what I have Pirelli pzero not peri Nero or anythin els
Old Sep 16, 2012 | 02:44 AM
Hakop's Avatar
2005 CL55
My offset is 34 rear 35 front my front is perfect
