CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Stuck in Park
Old Aug 24, 2012 | 04:12 PM
bimerbenzbently's Avatar
CL55 AMG/S55 AMG
Stuck in Park
I got stuck in park today and couldn't move the shifter to drive..
I wiggled it and tried all sort of things then it finally moved to drive I hope my tranny is not the issue here
Hopefully someone can help me out
Old Aug 24, 2012 | 05:19 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
I think it has to do with some plastic piece that breaks. There is a thread about this. The replacement piece is metal. I will see if I can find it.
R.K.
Old Aug 24, 2012 | 05:21 PM
radride's Avatar
Found it:
https://mbworld.org/forums/cl-class-...nsole-fix.html
R.K.
JPhamily's Avatar
Mercedes CL55
My car will do this time to time but I do the same thing like you. I heard its like 2-300 to fix. Doesnt really bother me much so I never got it fixed yet.
Old Aug 24, 2012 | 07:14 PM
awiner's Avatar
2003 CL55 AMG
Two options if it is the shifter lock mechanism.
#1 Remove it and you will no longer have an issue but will lose the safety lock feature. (Search for instructions which have been posted)
#2 Replace the broken plastic locking mechanism with the reproduction plastic or aluminum part. http://www.cart.com.au/mono-global/view/2592
Old Aug 24, 2012 | 07:26 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Good luck. It's a pain to do, but something we all endure.
Old Aug 26, 2012 | 10:03 AM
CL55 AMG/S55 AMG
Thanks for the help guys it's much appreciated
Old Aug 26, 2012 | 12:36 PM
awiner's Avatar
2003 CL55 AMG
By the way, if you are still stuck there is a way to possibly get the lever out of park.
Remove the shift knob. Put a pieces of wood or protective material on the op of the shift rod and tap it only with as much force as needed with a rubber mallet to bounce the lever and the rod free as you pull it out of park.
Be careful as the air bag module sits under the shift box and it you hit it the air bags can deply.
This will
Old Sep 7, 2012 | 06:21 PM
XZACM102's Avatar
AMG C63s Coupe
Had the same issue, stealer charged me $1200 this week for replacing the whole shifter unit.
Old Sep 7, 2012 | 10:44 PM
dls55amg's Avatar
2003s55amg
same issue here also,03s55amg shifter locked at 1am in the morning in montgomery alabama,slept in car stealer charged 1200.00 to replace ,ooooouch,now wife wants to sell
