CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Car vibrates between 2-3000 rpm.
Old Jul 15, 2013 | 09:43 AM
  #51
AndreNY's Avatar
couple of Benzos
Originally Posted by JPhamily
The car only raises when I put it in park but it takes a couple minutes untill it actually starts to raise and when I put it back to drive or reverse it goes back down to my normal height setting. I noticed this when ever I leave my car on and step inside my house for a bit or when I'm waiting for someone. I just want to know if replacing the pulsation dampener will fix that problem too.
Wow I have the exact same problem with my car LOL maybe our cars were twins at the factory
I replaced the Vibration Damper and the "noise" is still there my trans mount is completely shot and the left side engine mount is pretty much broken so they are all being replaced this week with Lemforder OE.
As far as you car going up in park my car does the same you have bad Height Sensors and this problem usually happens CL's that are lowered (I know yours is and so is mine) a friend of mine told me not to worry however it does kinda suck when you are chilling in Park and the car goes back up to stock height
Old Jul 15, 2013 | 09:53 PM
  #52
AMG 17GT's Avatar
R Nine T
Good day all
Just got car back and wow what a difference. I believe the following:
That the low rpm whine and humming was coming from ABC pump and the dampener quelled those vibrations.
The trans and motor mounts killed any accel and decel vibration.
This car feels like new and is almost passive now. I hope this thread helps any others with same problems.
Old Jul 16, 2013 | 01:19 AM
  #53
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Sounds like your pump is not putting out enough pressure. Have you had the car rodeo'ed to confirm it's running optimally?
Old Jul 19, 2013 | 02:13 PM
  #54
AndreNY's Avatar
couple of Benzos
For the noise or the car going up in park??
Old Jul 19, 2013 | 04:35 PM
  #55
AndreNY's Avatar
couple of Benzos
BTW Engine and Trans mounts changed 2 days ago the vibration is GONE
Old Jul 19, 2013 | 09:27 PM
  #56
JPhamily's Avatar
Mercedes CL55
Not only does my car raise when Im in park but the front end raises up like a air plane taking off on a runway when Im driving and when I come at a complete stop it lowers back down. This only happens when Im driving low speeds but when Im on the freeway its at my regular setting. This is so annoying! My car looks like a low rider with the front up and back down.... Is this also caused by bad sensors?
Old Jul 19, 2013 | 11:14 PM
  #57
alx's Avatar
alx
Via das read the height sensors in all four corners. If plausible, your front accelerometers(s) are implausible and need to be replaced.
This is assuming you car does not sink when left overnight. If it does your front valve body is leaking both ways. In that case there will be codes showing shock movement when supposed to be locked.
Old Jul 20, 2013 | 08:29 PM
  #58
alisohail's Avatar
2003 CL55 AMG
My cl vibrates above 70mph.....any ideas?
Old Jul 24, 2013 | 04:22 PM
  #59
alisohail's Avatar
2003 CL55 AMG
my w215
Attached Thumbnails Car vibrates between 2-3000 rpm.-1072266_1395864607299655_236542033_o.jpg
Old Aug 17, 2013 | 06:04 AM
  #60
John 99CLK430's Avatar
1999 CLK430 (sold) 03 CL55
Originally Posted by ROMEO550
Good day all
Did you get your Air Cell/Pulse Dampener/Accumulator whatever you want to call it, replaced? If so which one, there are 2 up front..
I have the same humming issue that resonates clearly from the driver side, thinking that it could of been the driver side accumulator/Pulse dampener/Air Cell whatever lol, replaced that with an OEM part number 220 327 01 15 along with repairing the valve blocks but the noise persist. I have OEM part 220-327-02-15 for the passenger side.. is that the fix?
Old Aug 20, 2013 | 09:24 AM
  #61
AMG 17GT's Avatar
R Nine T
Ill check today, but whine was coming from drivers side and they did use an updated part. I will see about part number.
That whine and buzz was more annoying on a daily basis then the other vibrations.
Edit. They didn't list part number on invoice sorry.
Old Aug 20, 2013 | 07:05 PM
  #62
JamesC32's Avatar
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
vibration
Might check your driveshaft flex plates, that's what mine did when one cracked all up..
Old Aug 21, 2013 | 09:28 AM
  #63
AndreNY's Avatar
couple of Benzos
Did you car vibrate or shake?
Old Aug 21, 2013 | 01:26 PM
  #64
JamesC32's Avatar
vibration
It only vibrated when the car was moving and when I would let off the gas peddle, or just barely toughing the gas peddle, when I would give it a little gas it would stop because there would be more tension on the flex plates..when I got under the car and looked at them the one on the trans was cracked very badly and the one on the differential looked REALLY BAD..
