CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Car vibrates between 2-3000 rpm.
Old Nov 5, 2012 | 03:06 AM
JPhamily's Avatar
Mercedes CL55
My car vibrates around 2-3000 rpm, does anyone know what might be the cause of this? One of my friends said it might be the flex disc?
Old Nov 5, 2012 | 08:16 AM
biker349's Avatar
cl600
could be engine , trans mounts.
Old Nov 5, 2012 | 11:46 AM
awiner's Avatar
2003 CL55 AMG
Id concur. Check BOTH the flex discs (also check that the bolts/nuts are tight in these and not missing), as well as engine and trans mounts.
Old Nov 5, 2012 | 01:04 PM
layzie12g's Avatar
2008 Mercedes Benz E63
I also started to get a strange groan in my car between 1100-1400 rpm. I think mine is the ABC pump starting to go bad.
Old Nov 5, 2012 | 01:24 PM
CharlestonN's Avatar
03' CL55 AMG
Mine was doing that and i had my Transmission mount replaced, helped a lot but now my Engine mounts are going bad so it's vibration from that
Old Nov 5, 2012 | 03:00 PM
awiner's Avatar
2003 CL55 AMG
My guess is that you will find a torn trans mount.
The motor mounts are fluid filled, however, they wear out long before they tear and leak fluid.
The flex discs take a ton of abuse, but are pretty hardy. Be careful however; If the front flex disc breaks apart it can be thrown up in the trans tunnel. The airbag module sits under the shifter and in rare cases the flex disc hits that area and can set the air bags off ! Doh !!!
Old Nov 5, 2012 | 03:36 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
trans mount or flex discs are my two cents.
Old Nov 5, 2012 | 11:18 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
I think you should sell the car JPham....seems like there's been a lot of problems with the car these days
Old Nov 7, 2012 | 11:45 PM
Simbad's Avatar
AMG GTS
me too
Be interested in what you find it to be.
I have a similar thing, maybe.
Mine is a deep subtle vibration that feels like it is coming from the driveshaft. Maybe somewhere between that and the rear axle.
It is worse when cold.
Old Nov 8, 2012 | 01:18 AM
BR34K3R's Avatar
04 CL55, 04 SL55, 2013 Panamera GTS, 1987 944 Turbo 420WHP, 04 Dodge Viper, 2011 E550, 2013 Accord
Depends if it is vibrating during idle or while driving or both.
Possible culprits would be:
Pulsation Dampener
Engine Mount
Transmission Mount
Flex Disc
The engine mount will leak when bad but it doesn't mean that just because the are not leaking they are good. The engine mounts are relatively cheap so is the tranny mount. I would change both if its been a while.
Engine Mount:
FEBI or Meyle $55-75
Part Number 230 33133 280
Transmission Mount:
Meyle $20-$24
Part Number 232 33019 500
Flex Disk Kit:
FEBI $133
Partnumber 428 33044 280
It will really help if you check to see exactly when the vibration occurs and how profound it is.
Good Luck,
BR34K3R
Old Nov 9, 2012 | 12:50 AM
JPhamily's Avatar
Mercedes CL55
Thanks a lot guys for the helpful information. I will get too this as soon as possible.
Old Nov 9, 2012 | 12:56 AM
JPhamily's Avatar
Mercedes CL55
I love my car man, Im pretty sure you did too until you started having abc problems. My car is at 135k miles now, I guess this is the time when all the problems start? What car are you picking up after you sell your 55?
Old Nov 9, 2012 | 02:08 AM
driveability's Avatar
Cl65 AMG
Pulsation Dampener
Engine Mount
Transmission Mount
Flex Disc
Engine Mount:
Transmission Mount:
Meyle $20-$24
Flex Disk Kit:
FEBI $133
Good Luck,
BR34K3R
I've had new engine and trans mounts sitting on the shelf for 6 months. There cheep but installing them is another story(CL65). I am going to install another A/C pump(to cool the I/C fluid) in the next few months, I will remove the engine to do the mounts and fit a second A/C pump at the same time. I feel the vibration and If I stand on it from a stop can feel the engine lift as well. I don't do that anymore
Old Nov 9, 2012 | 09:23 PM
JPhamily's Avatar
Mercedes CL55
So Ive been thinking, since my car is lowered and it sits pretty low to the ground, do you guys think its possible that the transmission crossmember bracket got banged up and caused the mount to go bad because thats where the transmission mount is located. My car always scrapes whenever I go over speed bumbs, even when I have it on the highest setting. Before anyone says anything, I love my car lowered!
Old Nov 9, 2012 | 09:54 PM
OCKlasse's Avatar
MBworld Guru
The mount just goes bad...takes like 20 minutes to swap out.
Old Nov 9, 2012 | 09:56 PM
JPhamily's Avatar
Mercedes CL55
I was going to pm you what I just posted because your lowered too but I just decided why not post it on here haha. Yeah Im going to change it out regardless, just wondering if being lowered has anything to do with it.
Old Nov 10, 2012 | 12:34 AM
BR34K3R's Avatar
If your handy it's very easy and cheap to replace, at $20 you can do it at every oil change that how cheap it is. Not that you should, I'm just trying to make a point...that, why not replace it if your even slightly thinking that it might be the problem.
Engine mounts are oil filled, cold starts will have a slight shake (miss fire feeling ) when cold and it will go away when warm. Tranny mounts, you can feel through engine speed at 2000rpm and above. The second I feel that mine are bad I just replace them. I've done it many times and it's very easy...for me at least.
If your the type that takes your car to the mechanic it will be cheaper if you do it all at once.
For example if your going to change your engine mounts, you might as well change the tranny mount too. The mechanic already has your car on a lift and he/she will charge you much less if you do it while doing the engine mounts. It's only $20, go for it.
Just my 2 cents
Old Nov 10, 2012 | 01:19 AM
OCKlasse's Avatar
MBworld Guru
Yeah, I doubt being lowered would affect it...while you're up there, check the flex disc for cracks, as I am sure those will prob need to be swapped.
Old Nov 11, 2012 | 04:42 PM
iAMGod's Avatar
996tt
Not a big deal, as has been said either an engine or transmission mount. This happened on my CL55, had them replaced, good as new.
Old Nov 17, 2012 | 11:43 PM
layzie12g's Avatar
I just replaced my pulsation damper. I just took the old one off and spun the new one on. It completely fixed my weird groaning noise I was having. It cost $155. I'm extremely happy that this took care of the problem. It was so annoying.
Old Nov 19, 2012 | 11:51 PM
Simbad's Avatar
AMG GTS
mine in the shop
Getting brakes done and checking on the vibration, will let you know...
Old Nov 24, 2012 | 01:36 AM
Simbad's Avatar
AMG GTS
As suggested engine and gearbox mounts replaced.
Old Nov 26, 2012 | 01:48 AM
Simbad's Avatar
AMG GTS
wow, picked her up from the shop today and it's amazing what a difference those mounts have made. I guess I quickly got used to the vibration but the car is SO smooth now.
nice.
Old Dec 3, 2012 | 08:21 PM
Yawnald's Avatar
CL55 AMG
Part number?
Old Dec 3, 2012 | 08:23 PM
OCKlasse's Avatar
MBworld Guru
Which would did you replace? The one off the pressure relief valve?
