CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC FAULT
Old Dec 20, 2012 | 03:24 PM
cl600v12's Avatar
cl600 bi turbo
Post ABC FAULT
Hi all, can anyone please advise. my Cl600 2003 has started displaying warning on dash when the car has been used and then switched off. When restarting car after a few moments the warning appears on dash, and the car feels to ride harder on suspension and the raise up feature does not work, leave the car off for a couple of hours and the fault clears. A new ABC pump was fitted 4 years ago at 50,000 miles, now at 85,000. Cheers.
Old Dec 20, 2012 | 03:42 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
What is the warning saying? What color is the warning messge? I would get the codes pulled.
R.K.
Old Dec 20, 2012 | 03:53 PM
cl600v12's Avatar
cl600 bi turbo
warning is red and reads ABC fault drive carefully
Old Dec 20, 2012 | 04:21 PM
radride's Avatar
Go to your nearest dealer or indie mechanic and get them to pull the codes. If the car isn't raising up when you push the button, then its not looking good.
R.K.
Old Dec 20, 2012 | 04:45 PM
cl600v12's Avatar
cl600 bi turbo
Thanks for help, will try to get codes, just seems strange that all OK when been standing idle for a time.
Old Dec 20, 2012 | 05:57 PM
sk91's Avatar
2005 CL55 AMG
Most likely a hose leak, which can cause the dash to have that come up.
Check the undercarriage for the hose located by the transmission going from left to right.
Do not drive the car as if the pump goes dry, your going to have to replace it again.
I had my hose custom made from a shop (very cheap $80-100) and its really good quality, better then oem.
Once I had my hose fixed, I had to refill with abc fluid and bleed the system since air can get in. After a night, the car stopped raising up, and I thought my pump was gone, but then a friend recommended to force pressure the pump via the reservoir and it worked! Ran the rodeo test and the pressure was stronger then before.
Never had a problem since.
Total bill was $100 for hose, $80 for labour, $29 for fluid, $80 more for bleeding/rodeo.
Hope that helps, good luck.
Attached Thumbnails ABC FAULT-img_20121203_143839.jpg   ABC FAULT-img_20121203_145634.jpg   ABC FAULT-img_20121203_161933.jpg
