CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL600 - CL65 engine difference
Old Dec 31, 2012 | 06:23 PM
Gerry_C's Avatar
'13 E550 Cabriolet
I have seen a CL600 that was "upgraded" to CL65 for sale for a few weeks now. (http://www.cars.com/go/search/detail...nal&listType=3) Knowing this was in all likelyhood a "badge" upgrade and nothing more, I did call the owner/seller.
What is the easiest way to spot the engine difference?
The owner does not know anything, the car is as he purchased it. He did indicate there might be a problem with the agc pump as he stated it would cost $1200 and he would adjust the price accordingly. On the off chance an earlier owner did put a real CL65 engine in I hate to pass this up.
Old Dec 31, 2012 | 06:29 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Well considering its a 2001, it won't have a twin turbo V12. If he truly swapped the AMG Twin Turbo V12 in it, one, it would of cost him a fortune and two, he wouldn't be selling if for this cheap. Take a picture of the engine bay and post it here.
R.K.
Old Dec 31, 2012 | 06:38 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
A cosmetic clone (without the front and rear bumper or brakes). Nothing more, nothing less.
Old Dec 31, 2012 | 07:25 PM
02cl55amg's Avatar
CL65
Looks like a 2001 CL sport with 65 wheels. Big diff between a 01-02 v12 and 03-06 v12tt
Old Dec 31, 2012 | 08:29 PM
Gerry_C's Avatar
'13 E550 Cabriolet
R.K.
I know the standard CL600 is very different. However, it could be possible to swap the engine and control electronics from a totaled CL65 (some must have been totaled by now). Changes (probably only cosmetic) were done by an earlier owner, so this guy really doesn't know anything. I will try to see it this next week as it is only 1/2 an hour away. I will take pictures of the engine bay if it does not stand out as being a stock 600. How hard is it to see the turbos and plumbing on this?
Old Dec 31, 2012 | 08:39 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Run away. I don't think it is possible to have an ABC pump changed for $1,200. Could be a miriad of problems and may need a new pump, shocks, accumulators, hoses, ETC, ETC. You could easily reach $10k at the dealership depending on what is wrong.
Don't ever buy a 2000+ CL with ABC problems. You want one that has all of that replaced. Let someone else bear the expense of getting the ABC maintence up to date.
Old Dec 31, 2012 | 09:22 PM
radride's Avatar
The turbo V12's had intercoolers on the tops of them. When you take the engine cover off you will see two big squares towards the fire wall; one on each side mounted to the motor. That's a dead give away.
R.K.
Old Jan 1, 2013 | 12:06 AM
Gerry_C's Avatar
'13 E550 Cabriolet
R.K.
Thanks, that is the info I was looking for.
Others have mentioned run away from suspension problems. I do understand that those problems can easily run into big bucks. A great system when it works but many possible problems and big sums of money to get right sometimes (especially from a dealer). I would only be interested if it had the AMG engine though.
