Replaced Fuel Filter - Interesting Find
Removal and replacement was simple. 20 Minutes from start to finish. If you do this, take the gas cap off first to depressurize the fuel system and be ready to swap the new filter in once hoses are removed to reduce the fuel loss/spilling). It may help to use some clamps to help close off the hose ends when removing, but I did not do this. I just made sure I could do a filter swap quickly.
I did not need to jack the car up, there was enough room even though my car is lowered a bit to accomplish this task with the tires on the ground.
Tools/Items needed:
10mm hex socket (to remove plastic compartment just forward of driver side rear tire)
Phillips screw driver (to loosen fuel filter clamp)
Small standard screw driver (to remove OE clamps)
Pliers to reinstall fuel line clamps (Unless you buy new standard clamps with a hex/screw driver head)
New fuel filter (part A002-477-27-01)
I have to admit, the low speed "slight idle 'stumble" I have become accustomed to disappeared once the new fuel filter was in place. Obviously there must have been an obstruction in the fuel filter that caused the stutter at low idle. I was curious as to what was obstructing fuel delivery in the filter so I cut it open.
I was shocked to find that the filter element inside the thick aluminum can was made out of a CARDBOARD type material !
126,000 miles and 10.5 years of fuel really made this cardboard material tough. I wonder if this was causing an obstruction of fuel through the filter.
With a new Bosch fuel filter priced at ~$20.00, my recommendation is change it every 4 years or 50,000 miles.
A dirty filter will manifest itself far more at higher rpms than at idle. If the low rpms were the only thing that has improved - a dirty fuel filter was not your culprit. Just a random thought...
But yes, they do get neglected/ forgotten and do accumulate junk inside. I have seen a few that were as you found out- pretty rough.
I want to buy it Aftermarket from Mahle oder MANN Filter, like i always do, since they are the OEs and do the best filters overall.
But my Program shows me two different filters for that PartNumber.
One is with a single 8mm inlet and 8mm outlet, but also they show another one with 2 inlets as well as two outlets. Also these last mentioned filters do cost 2.5 times as much as the ones with only one inlet and outlet.
Which one is the right one?
Tools/Items needed:
thanks
Thanks!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Only as i wasn't seeing the stock hose clamp from the outlet of the filter, i used a car jack to get fully under the car which made it alot easier obviously.
I used a "hose close pliers" to shut of the line from the pump to the filter and do the swap.
I used high quality "multi-use" clamps with 7mm hex head as a replacement.
Before i put the new filter in, i blowed with my mouth through the old and the new one for a comparison and the difference is like night and day. I dont know how old the filter was that was in the car though.
Results:
Despite i replaced air filters and spark plugs two weekends ago (Spark plug change PITA! was 9 Hours work!!!), i still had slight stumble at idle.
My slight stumble at idle and sometimes even a slight visible RPM variation at idle, every minute or so, is now fully gone after the fuel filter replacement. Idle feels a lot more smooth - i can highly recommend to do this every 2 years or so.
9 Hours for a plug chage? What did you find was the issue? I had mine old ones out and new ones installed in less than an hour and a half.
I used a veeeery long wrench (half body length) and a flexible cardan joint. I had to push with my whole body weight EVERY TURN against the wrench with my right arm to make a turn. At the same with my left arm i turned the wrench to have it allinged properly because of the flexible cardan joint.
At every turn there was such a loud whine from the heads/plugs thread, like if you havent removed your winter wheels for years. With every turn i prayed that the plug wont break apart so that i wont have to remove the cylinder heads.
I had to use that much force up until the last thread pitch on every single plug!!!
After 3 plugs i was already so much out of breath and had pain in my shoulder and arms like doing 3 headgasket changes on a V8 after each other. And as i was done to replace them, i noticed that two plug boots wont snap-in properly onto the plugs. I looked into them and i saw that two copper-connectors of the old plugs broke apart as i was pulling the boots and the copper connectors stuck in the plug boots. Imagine that!
So i ordered two new plug boots which i installed the day after.
I was aware of that before, that a plug change on the M113 engines can be a nightmare (read tons of nightmare stories on the internet) and yes it was - even though thank god none broke apart that something was stuck in the cylinder heads...
Just as Crissus states, over half of them never loosened from the first turn to the last and were a major amount of wrenching to get the whole lot removed. My plugs were original with 77K miles on them. I never experenced this with Japanese aluminum heads.
Upon reinstall I made sure to use a copious amount of anti seize on the threads as well.
Changed my wires at the same time so I did not have any issues there either. Luck sometimes is great!
sorta off topic, but ive read not to use anti sieze on MB plugs?
sorry to dig up old threads but this was an early google result after searching for "w215 fuel filter change"
now it seems that I have the wrong fuel filter...i have two inlets and two outlets on the fuel filter i ordered...
i will say, spark plugs was always a fairly easy job on my m113. they are annoying to access but much quicker than some other vehicles ive worked on. my plugs always easily come out, maybe has to do with the lack of snow/salt here in florida...
edit:2002 cl55 fuel filter has two inlets and outlets It turns out
