CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Single Digit MPG
Old Apr 5, 2013 | 09:44 AM
stamper197's Avatar
2005 CL55 AMG
Single Digit MPG
So when I had my ABC System fixed, and new spark plugs and A+B maintenance and all fluids changed over to synthetic... super charger intercooler replaced, and other things done etc...
Before I turned the car in it was getting about 16 mpg city driving, now it doesn't get past 5 mpg city driving. I know the ECU was reset due to the extended periods of time with no battery hooked up but geez, its been a week now and still the single digit numbers. I am not driving bad in the car.. do I keep it in DS or CS? I have ABC Sport mode engaged just to keep the wear and tear down on the ABC system but it was that way before all the fixes, I don't get it..
Anything I should be checking?
-Ron
Old Apr 5, 2013 | 10:07 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Is the MPG consistant with what you are seeing driving and your gas gauge?
R.K.
Old Apr 5, 2013 | 10:23 AM
stamper197's Avatar
2005 CL55 AMG
Ohh yes I can now see the gas gauge visibly go down as I drive around town.
Old Apr 5, 2013 | 12:54 PM
Welwynnick's Avatar
2006 S600
How's the performance? Any warning lights or messages?
If the engine is using that much fuel, its likely that there will be some OBD2 messages - misfire, too rich, Lambda fault, that sort of thing.
Was the intake plumbing removed during the work? I would check it all for alignment, leaks, dirt, missing seals etc.
Nick
Old Apr 5, 2013 | 01:34 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Ron, sometimes when the battery is unplugged, the instrument cluster will lose certain settings. For instance, some instrument clusters are programmed to start at around 16mpg, when the car starts up and then goes up or down from there.
But when the instrument cluster is unplugged or switched, they are sometimes inadvertently reset somehow and they seem to start at around 6mpg and go up from there.
The main thing is, your "After Reset" should be accurate after around 100 miles. And that the car isn't actually getting 6mpg.
So the question is; are you really getting 6mpg, or is your instrument cluster telling you you're getting 6mpg? You can't believe the trip computer, they're always off. Fill up your tank of gas, reset the trip odometer and the "after reset" trip computer, drive normally for at least 200 miles, refill your tank at the same gas station, and determine your true mpg by dividing your trip odometer with the exact volume of fuel you put into your tank. This is always different than what the after reset trip computer says.
Old Apr 5, 2013 | 08:14 PM
stamper197's Avatar
2005 CL55 AMG
I was referring to the after restart trip computer. Ie what you did during that days driving.
-Ron
Old Apr 5, 2013 | 08:18 PM
radride's Avatar
Well if you are truely getting 6mpg, then you should run out of gas after 115 miles... I doubt that is happening.
R.K.
Old Apr 5, 2013 | 08:31 PM
stamper197's Avatar
2005 CL55 AMG
R.K.
You sir have a point.. 47 miles city driving took about 25% of a tank away it is getting better the mpg is going up. Apparently someone had noted in the ECU thread that it takes about 16 starts after an ECU reset for things to normalize. So I am not in that window yet, but I do see things improving.
Thank you everyone for your replies.
-Ron
