2003 cl55 amg trunk/ doors/ audio/phone
Here are a few questions...
I just purchased a 2003 cl55 amg. The auto trunk does not fully open and it seems to close a little too fast. Any Ideas, suggestions?
also the doors appears to be a little rough w/the windows up when you open it because of the slight drop. It's smooth with the windows down. Is this normal?
Being that is a 2003 there is an old phone hook up. Is there some type of adapter so I can use an iphone for the handsfree?
Can you hook up a rear camera to the nav screen? can you hook up Satellite?
TY
Read the manual. In the section regarding the electric trunk, it will explain the procedure to set the full open position.
I don't understand the question. What do you mean by the doors are rough?
There is a blue tooth puck that fits in the telephone cradle. They are not made anymore, but you may still be able to find one for approx $400 or so.
Not without significant modification.
TY
For the trunk, if I recall correctly, car running trunk closed, press down on the trunk switch in the door as if to close the trunk for 5 seconds and next time you open it should go all the way
when i mentioned the door seams rough w/ the window up, it is when the window does a slight drop before opening. It almost seems like the door drops because it it out of alignment. It's smooth when window is down.
As per the door thing normal as well. When you open the door from the inside wait a brief second for the windows to lower so you can open the door fully. You will get used to it.
