cl55 power trunk help
I would like to know if there is a way to override or turn off the time out to auto close?
It always seems to hit me in the back when I least expect it
What is happening is the trunk struts are worn and need replacement.
The struts are no longer able to hold the trunk up for a prolonged period of time.
You need:
A2157500336 (Left)
A2157500436 (Right)
Buy them they are very easy to replace. Took less then 5 minutes.
Will that also be why it wont open also unless i "help it" to get it going
i think i may have a weak motor too
Ill keep you updated
The weak opening is usually an issue of not enough hydraulic fluid in the pump reservoir. After many years the o-rings start to shrink/crack/leak and fluid is lost.
The pump/reservoir is located in a compartment under the battery. Remove the battery, pull the pump/reservoir out. Remove the reservoir cover (simple metal clamp holds it on) and fill up to the fill line.
Replace and cycle open/close several times.
I assume the fill line is the "+" symbol.
Given that the trunk is open and fluid is in the lines this would give room for the fluid to return to cup when closed.
It works better so i hope the shocks will help
thanks
frank
Yes, that is correct. The fill line is lower than full so when the trunk is closed the reservoir has room for the fluid pushed back in due to the ram being retracted.
Also, what are the best options for Bluetooth and AT&T in my new to me 2003 CL55? The Mercedes site does not show their puck working with AT&T, and the dealer is talking about a partial replacement of some parts rather than just a slide in puck like my 2006 S65 has.
If you have the factory telephone system, there is a puck that works. The puck is no longer made but you can find them second hand if you look.
Could open with key and lift up
Could use power close worked fine...
removed rear trim panel to inspect
Found vac diaphragm tabs broke off for vac trunk lock release dash pod.
if that does not release trunk can not work
Was able to repair dash pod with epoxy and all works ok now
dont realize how much we use this option
Mine will unlatch and start to open, buy it acts like the pump is too weak. If I give it a little help to get started going up with my hand it will open on its own. Fluid is fine and trunk struts are not very old. I'm trying to figure out if my pump is going bad or what.
