Is there an adj for the closing tension of the sun roof?
It goes about an inch away from close and reverses to half way-Nothing in way and not binding.
If I hold button closes with no issue.
It's a programming issue I had mine repaired but it was under warranty took no time at all
Originally Posted by amgcl55
Is there an adj for the closing tension of the sun roof?It goes about an inch away from close and reverses to half way-Nothing in way and not binding.
Read page 207 in your owners manual...
R.K.
Quote:
R.K.
My book was 205-Originally Posted by radride
Read page 207 in your owners manual...R.K.
Pop up rear of roof
hold 1 sec
then open and close
should reset
no change-tried 3 times with same result-roof goes about 1 inch from close and reverses open half way
Also found out the "summer feature"(window roll down and roof open) does not work-maybe related?
Must be programming like was stated
Last time something weird was going on with mine I pulled the fuse, counted 10, then reinserted and everything was back to normal.
Quote:
Pop up rear of roof
hold 1 sec
then open and close
should reset
got a scanner and ck codes-Originally Posted by amgcl55
My book was 205-Pop up rear of roof
hold 1 sec
then open and close
should reset
code B106B is in overhead module for switch
stored and restored after reset
says coding of OCP not permissible and asks for presafe to be set as INACTIVE
Could this be why my SR is acting up
In short.... YESOriginally Posted by amgcl55
got a scanner and ck codes-code B106B is in overhead module for switch
Quote:
also found a TSB-68.49/20a that states...Originally Posted by awiner
In short.... YES
the memory for the RV mirror was no longer avail after chassis 039991(mine is 0456430)-so it can NOT be deleted and ignore it
OH well
Thanks ADAM
I also looked for the presafe and could not find it in any module
ExploreCurrently Active Users (1)
