CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Coilover kit to replace our ABS system
Old Sep 9, 2013 | 02:15 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
http://www.strutmasters.com/Mercedes...arts-s/110.htm
anyone ever heard of this kit and knows anyone who has done one? I just noticed this pop up on the CL section and guessing a coilover kit for around $2,000 is way better than going on to fix our ABS once it gives out.
Any input would be great.
Old Sep 9, 2013 | 04:46 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Nice!!!
Old Sep 9, 2013 | 04:56 PM
AndreNY's Avatar
couple of Benzos
it's not worth doing it with the ABC system way too complicated, with Air suspension its plug and play...
Old Sep 9, 2013 | 05:54 PM
shardul's Avatar
so if the pump is still running. the hoses and the pump are still prone to failure and if they fail they will still have to be replaced in order for the power steering to work?
Old Sep 9, 2013 | 07:02 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Plus OP, you can't lower the car because there isn't a lowering spring available. So if you like stock height, enjoy the struts.
R.K.
Old Sep 9, 2013 | 07:38 PM
alx's Avatar
alx
The abc is the best thing going for our cars. I would not replace it with a coil over system at any cost.
Old Sep 9, 2013 | 08:42 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Our cars are way to heavy for coil overs to perform well (IMO) VS our ABC system. The ABC is a great system to make a heavy car drive and handle " more" like a much smaller car. I saw a CL600 with coil overs but it was a drag race car only.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 16, 2013 | 09:20 AM
I will be picking up my car hopefully sometime this week from speedriven i will show this kit to Marcin and see what he thinks about it.
