CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
HELP: V12TT problems with whining sound and low BOOST *video* PICS
Old 01-13-2014, 03:21 AM
benz_addict's Avatar
V12TT
My V12TT developed a whining sound coming from the left (driver's) side of the engine. It happens ONLY after letting go of the accelerator and whines down the the engine RPM's. If I floor it the whine goes away completely.
I am also having a boost problem. It doesn't feel as fast as it used to be.
Here is the video of the sound:
Can it be the diverter air valves?
Old 01-13-2014, 10:25 AM
xabo's Avatar
'08 CL65
"This video does not exist"
Old 01-13-2014, 09:24 PM
V12TT
LINK fixed
Old 01-14-2014, 08:32 AM
xabo's Avatar
'08 CL65
What was the problem?
Old 01-14-2014, 09:24 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
I think he meant that he fixed the video to show up.
That is a weird problem you sure its not coming from the rear end?
Old 01-14-2014, 12:02 PM
xabo's Avatar
'08 CL65
Okay….thanks
Old 01-15-2014, 01:38 AM
V12TT
I mean I fixed the link to the video.
Problem still persists. DEF from the front driver side
I did change the deceleration divert valve with new spring but no changes, no vacuum leaks either and no pinching lines. Whining is still there. I'm wondering if it could be the ABC pump, but why does it only whine if I build boost then let off the throttle?
Old 01-15-2014, 10:21 AM
alx
alx's Avatar
Belt or pulley bearing. Or water pump or alternator. Something rpm related.
Or gears. Check tranny for metal particles/ dust.
Old 02-12-2014, 01:45 AM
V12TT
Boost fixed, new pump and proper bled.
Noise fixed, was the ABC pump.
Thanks for the help!
Old 02-12-2014, 11:42 AM
Dr Matt's Avatar
05 CL65
So what fixed the low boost problem?
Old 02-12-2014, 02:46 PM
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
You mean a new circulation IC pump?
Old 02-12-2014, 06:22 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
His IC pump crapped the bed.
R.K.
Old 04-18-2014, 08:21 AM
JRockey's Avatar
2008 CL65
My '08 is making a whining noise at 2500 rpm. It happens in neutral so that eliminates the driveline. It is more pronounced on deceleration like the OP but it is downright irritating to drive on the hwy at 75 mph. I had it at the dealer yesterday for an unrelated problem that they couldn't fix so I had them take a listen to the whining. Their recommendation - "keep driving it". That's right - they know there is a whining and its irritating as hell but want me to keep driving it. I think I will just take it to another dealer
Quick Reply: HELP: V12TT problems with whining sound and low BOOST *video* PICS
