CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABS, ESP and BAS problem CL55 AMG 2004
Old Mar 27, 2014 | 05:10 AM
Energiiz's Avatar
C63 AMG W204 SOLD: CL55 AMG V8 Kompressor E55 W211/CLS63 W219
Hi evryone!
I have a CL55 V8 Kompressor W215 that i have owned for 4 months now. The first problem id got was that the car one day didn't want to start like that i didn't have any electricity but after i tried 5 times the car started but with some faultcodes like ABS, ESP and BAS and the brake lights are on?
I went to my friend and he changed the brake senor (small black little part that is on the brake pedal)
Sometimes the fault codes dosent apper, but sometimes they do. The car is living his one live...
// Erik
Old Mar 27, 2014 | 09:43 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you will probably need to change the module
Old Mar 27, 2014 | 09:52 AM
Energiiz's Avatar
Ok, wich one? The ABS module? or?
Old Mar 27, 2014 | 09:54 AM
biker349's Avatar
cl600
make sure your battery is fully charged.
Old Mar 27, 2014 | 10:24 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Open up the hood, on the rop right and top left corner there will be 2 covers. One of those covers was loose and not closed right one time and I had the same exact issues you were having.
Look into it and good luck
Old Mar 27, 2014 | 10:48 AM
Energiiz's Avatar
When you mension the battery, i also had som issuses with that.. After the car was on the parking for 7 days the battery was empty. But i recharged it. The battery was about 4 months old.
Old Mar 27, 2014 | 10:49 AM
Energiiz's Avatar
Smile
Hmm, i dont really understand. But im going to open the hood and see that all the covers are closed.
You maybe have some pictures or something?
Old Mar 27, 2014 | 12:50 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Turn your steering wheel all the way to the right and then all the way to the left while you are parked but engine running. Should remove the errors.
Old Mar 28, 2014 | 07:40 AM
Energiiz's Avatar
I will do that. Thanks!
Old Mar 28, 2014 | 08:53 AM
All of your wiring is under those covers so if they are popped open and not sealed correct you might have an issues. Make sure to pop all the covers completely off and lock them back in making sure its closed correctly.
Good Luck
Sorry no pics my car is in the shop so I can't take any at this time.
Old Mar 28, 2014 | 10:15 AM
Energiiz's Avatar
Good Luck
I found it, and i checkt it. Evrything seemd ok!
On Monday the car is going to a MB workshop to do a check. So i will come with the answers
