CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
metallic engine rattle cl55
Old May 16, 2014 | 06:00 PM
kneedeep's Avatar
2004 cl55
Im getting a sharp mattalic rattle up front near the belts. I searched and it seems like it's the inner Bearing on the 2 piece idler from what I've read. I'd love to get a second option before I start ordering parts. Here is the video I took.
Cl55:
Old May 16, 2014 | 06:43 PM
Dr Matt's Avatar
05 CL65
Take off the belt and fire it up to see if the noise goes away. Usually, with the belt off if you spin and try to wiggle a bad idler you can tell if it is shot.
Old May 16, 2014 | 09:12 PM
w4sim's Avatar
S55K AMG
My inner idler pulley broke in half a couple of weeks ago and the car went straight down on its ***.
As an emergency i found that i could take both the pulleys off and swap the front pulley over to the back to get the car started, raised, and drive a short while back to home.
But personally i would get it seen to BEFORE it breaks off.
Im pretty sure you can get a bearing kit pretty cheap for those.
Old May 17, 2014 | 09:19 AM
kneedeep's Avatar
2004 cl55
Is this the right part... Seems way to cheap?
Attached Thumbnails metallic engine rattle cl55-screenshot_2014-05-17-09-15-16.png
Old May 17, 2014 | 04:25 PM
w4sim's Avatar
S55K AMG
No, your idler pulleys that you are referring to have grooves in them for the ribbed belt to go on.
