window auto up and down problem
okay, my drivers side window doesn't lower slightly when i open the door and doesn't raise when i close the door. did the reset and no go. if i raise the driver's window all the way while in the car with it running and let off button immediately the window will lower about 3 inches. well i tried the passenger window and it wont auto raise, or lower when i open , or close the door either. tried the reset on both doors. no luck. is there a common module that works both windows? strange that both windows are the same.
is reset raise window all the way up, hold button for 3-5 seconds, lower window all the way and hold button for 3-5 seconds, raise window all the way and hold button for 3-5 seconds. that's what i did on both windows with no luck.
any help would be appreciated. btw, door speakers work on both doors and every other function on doors work including soft close.
