My Satellite Radio Install
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
My only concern was would the module be in the way for a front seat passenger. It's really not. It's up against the side of the console, so it hasn't been in the way.
will the signal be weak if you leave the antenna on the inside?
It's a little tricky getting the wire from the engine compartment into the door jamb, but it'll go.
I tucked it behind the rubber trim that runs along the side of the windshield.
