CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Question about stock rwhp on CL600
Old Dec 24, 2014 | 03:25 PM
SL55_Forever's Avatar
3-pointed star
Hi guys, I know there's a W215 sub-forum but it's not as active as this one, plus quite a few folks here jumped from CL600>CL65.
I'm trying to find out what stock rwhp the CL600 is? Also what does Eurocharged tune on CL600 add? Couldn't find that info on their website.
Old Dec 24, 2014 | 05:22 PM
3-pointed star
Just to add Eurocharge states:
STOCK POWER 493HP / 590TQ
EUROCHARGED TUNED POWER 593HP / 695TQ
But CL600 is known to make around 540hp/640tq from the factory so....?
Old Dec 24, 2014 | 10:22 PM
MooJohn's Avatar
00 Lincoln Continental
A 65 maybe, but not a 600. The 600 is rated at just over 500 at the crank.
Old Dec 24, 2014 | 10:39 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
some of the CL600 that I have seen dynoed are around the 430 rwhp range.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 24, 2014 | 10:46 PM
3-pointed star
So if 430rwhp is stock does the eurocharge tune add 80rwhp?
Old Dec 24, 2014 | 11:54 PM
F1BHP's Avatar
sl600
I think they increased the spec at some point from 490 to 510 crank and the Eurocharged tune gains around 95 crank on both.
Old Dec 25, 2014 | 11:11 AM
3-pointed star
Could you comment on stock crank torque and eurocharge tune crank torque?
Old Dec 25, 2014 | 11:58 AM
Welwynnick's Avatar
2006 S600
I think that's most people's common understanding of the FLYWHEEL figures.
I think the disparity comes from how the figures are measured. MB probably quote DIN 70020 or ISO 1585 measurements, which require the engine to produce max power for a relatively long, continuous period.
Quarter miles and dyno runs are much shorter tests than DIN, so a car that measures 540 on the dyno may indeed be 493 DIN. I bet the Eurocharged figures (or any other tuner for that matter) are not DIN or ISO figures
So I figure the 593 hp is real, its just not 100 hp more than a stock engine measured the same way.
Nick
Old Dec 25, 2014 | 02:51 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I went from around 390 RWHP to 525 RWHP with a Renntech tune on my old CL.
Old Dec 25, 2014 | 07:24 PM
3-pointed star
^ 150+ crank horsepower increase? I doubt that lol
Old Dec 25, 2014 | 10:28 PM
BlownV8's Avatar
I've posted the dyno charts when I did the before and after. Dyno shop had nothing to do with the tune. They were floored at how much it made with a.tune.
Old Dec 26, 2014 | 06:41 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Hello there
Old Dec 26, 2014 | 07:37 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
More like 130ish crank but it isn't far fetched, stock 600s were running 493 crank hp. Back when these cars were going for 140k vs 200k+ people were going for the 600 with a tune since it could make more power than a stock 65 with a 620-630 crank hp on a tuned vs a 604 stock 65 and save 50k+
525 rwhp with a tune isn't hard to believe even using a standard 18% drive train loss it's still roughly 620 at the crank.
Old Dec 26, 2014 | 07:51 PM
BlownV8's Avatar
My CL before the tune was definitely down on power. To me, it was underwhelming. After the tune, totally different car.
Old Dec 26, 2014 | 10:47 PM
3-pointed star
Is this generally with any tune or Renntech specific which looks like makes the most power ironically since Renntech is known to be conservative.
Old Jan 7, 2015 | 02:42 PM
3-pointed star
Curious as to how Renntech achieves the most gains from only an ECU tune compared to an only ECU Kleemann, Eurocharged, Speedriven etc.
Old Jan 7, 2015 | 04:30 PM
BlownV8's Avatar
Renntech may be much more aggressive with their tunes. They have more experience.
