Battery
It is a pain butt in the CL65 you must open hood and remove fuse block on passenger side. There is a positive cable that you can hook a booster to and then negative to a bolt to get enough juice to open trunk and charge battery. There are photos online somewhere but I don't have link.
Actually on a CL the alternate charge point is under the carpet on the passenger side. Pull back the carpet from the front (firewall) and under it you will find an aluminum plate held in place with 3 plastic nuts. Remove the plate and you will see where the main positive battery cable attaches to a distribution block. You can charge it there.
Or use your key to open the trunk and hook directly up to the battery.
Sometimes the metal key in the keyfob will open the trunk but I also had to use the floor junction point.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
