CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Kleeman Headers are in but need advice
Old Jul 23, 2015 | 02:09 PM
principledchiro's Avatar
2006 CL55 AMG
Hello guys n gals, in addition to EC smaller blower pulley, EC Tune, EC IC, Belt Wrap, and K&N air filters, now in are Kleeman shorty headers with mid length pipe. I'm in NY so California emissions equipment must be on car in order for muffler/exhaust shop to connect the headers to the remainder of the stock exhaust. In other words they won't weld up the exhaust unless there are cats in the exhaust stream. So going the route of one pair of cats (deleting second pair) connected to stock resonators etc. Eurocharged is deleting the CEL.
Is it recommended to use flex tubing after the headers so the engine torqueing on exhaust headers is minimized to avoid the primary tubes welds to crack? Wisdom appreciated. Thank you.
Old Jul 24, 2015 | 02:46 AM
Dr Matt's Avatar
05 CL65
No, never use flex pipe in a longitudinally mounted engine.
Old Jul 24, 2015 | 06:44 AM
2006 CL55 AMG
Oh, saw this with E55. Not sure of his long term result. Ok. not doing it.
Old Jul 26, 2015 | 09:12 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Why not? It's recommended around here quite a bit.
Old Jul 27, 2015 | 09:07 AM
a100steaksauce's Avatar
W218
Sounds like you need a performance exhaust shop.
Old Jul 28, 2015 | 05:23 PM
2006 CL55 AMG
Yes, indeed
Ok, Tomorrow the same exhaust shop is deleting the primary cats by hooking up the Kleeman mid-pipes to the Kleeman shorty headers. As most of you already understand there's a major bottle-neck where the stock exhaust manifolds meet the primary cats. What remains after the mid pipe are the stock secondary cats, stock resonators and mufflers).
They won't do all cats deleted. This is fine due to that having no cats allows for a stinky exhaust, excessive bark, and drone.
Jerry at EuroCharged emailed the revised tune (with headers) and CEL delete.
I'll keep all posted on the result.
Thank you to all who replied to this thread.
Old Jul 29, 2015 | 05:25 PM
2006 CL55 AMG
Didn't have a chance to see car but this is what the installer described: The up- stream O2 sensors were screwed in to the Kleeman header O2 sensor bungs, the primary cats were retained but the bottleneck leading to the cats were cut off, and they were welded and bolted to Kleeman Headers flange, then comes the Kleeman mid pipes with down stream O2 sensors, flex pipe on both sides (he wasn't able to place flex pipes near headers), deleted secondary cats, to stock resonators and mufflers. Tomorrow update.
Old Jul 29, 2015 | 06:13 PM
W218
post up sound clips
Old Jul 29, 2015 | 08:08 PM
2006 CL55 AMG
Will do
